iPhone 11/11 Pro
argentinafa
i believe is because mine is an exchange. i am not returning it? not sure about this as i dont go abuse their 14 days refund policy though. i buy from apple store as company paid for the phone and also for the after sale support like what i encounter :s13:
Oh yeah. That’s how they determine a genuine user from a flipper : ). You’re exchanging a set due to defects and still will be using the product. Not flat return-then the restocking fee kicks in.
KeYoKe
yea and maybe they will check the history of your purchases to see if you are abusing it too
argentinafa
Any experts know how to get rid of this circled stuff being shown on my iPhone 11 Pro Max? It keeps showing this on my Safari whenever I press the new tab (bottom right button).
I checked my iCloud data backup. I deleted my old XS Max backup. I checked under settings>safari>tabs. Couldn’t find a way to make this thing disappear.
EDIT: Prob solved. iCloud was actually using wifi to sync my last visited tab on Safari on my old phone. Suddenly got hwz website tab appear. I swapped left to delete it and the cloud icon is gone!
szeli
https://i.imgur.com/A8Ub6VW.jpg[img]
I checked my iCloud data backup. I deleted my old XS Max backup. I checked under settings>safari>tabs. Couldn’t find a way to make this thing disappear.[/QUOTE]
iCloud scroll down disable Safari tab syncing
KeYoKe
but guy using a red phone is more funny than the green, right? :s13:
What is so funny about that?? :s11:
If it is pink, maybe it is...
to be honest, i also dont find that it is funny.
everyone has a choice of color they like. does that mean guy cant like colors like purple, pink? yes it might be a more feminine color, but still i dont think that should stop someone from getting a color they like as the color is more suited for females etc...
cet87
if next year iphone 12 come out with pink phone, you will use it? :s13:
davidwong
All colours are ok la cos is for own shuang-ness only In the end still put an opaque cover over it after the initial showing off hype.
Important things which Color retain higher resell value when we ALL are switching to the really innovative iphone 12. iphone 11 series we all know only a stop GAP measure.
So just buy whatever Color pleases oneself can Liao
argentinafa
Tks bro. Offing the iCloud>Safari tab indeed will remove the cloud icon as shown by my previous post.
After I off, it ask 1)Keep on my iPhone or 2)Delete from my iPhone
I pressed keep. When I turn the tab on again, it asked “What would you like to do with local Safari data?” I press Merge. XS Max iCloud icon comes back again.
The phone can’t understand that I wanna sync the existing bookmarks under iPhone 11 Pro Max?
sgAshton
Loving my yellow iphone 11. The switch from a note 9 isn’t too bad. I prefer the simplicity of an iphone
