iPhone 11/11 Pro
metamofia89
Whyyyyyyy?????
Aesthetic reasons. I think I shall play safe and get the Space Grey or Midnight Green.
Don’t get me wrong, the silver looks clean as hell. But I think over long time the dark colours will please me more. First world problems.
ragnarok95
Senior Moderator
Senior Moderator
If i getting the 11 pro i will get the silver for sure. Because you can still polish the phone. Not so with the space grey.
argentinafa
U had the rainbow hue problem when ur pinkie finger rest at the bottom of your space grey right. This can be avoided if you don’t use cases with bottom exposed.
True that Silver stainless steel can be polished by cape cod polishing cloth. But Midnight green and Space grey have very dark color PVD coating. So less prone to get scratches.
I seen the display pieces of silver 11 Pro at Apple Orchard. Some pieces the bottom all scratched up until so bad.
ragnarok95
Senior Moderator
Senior Moderator
Nope, mine is at the mute button there. :s13: My bottom is still shiny. :D
KeYoKe
just need ensure the polish paste dont get in between the gaps of the buttons and the phone :o
argentinafa
How did the hue happen? Is it due to too Long never take out casing to clean your XS? Hence casing caused a hue marking?
I have habit of taking out case and clean my phone every 3 weeks with microfiber cloth. But to make sure cloth is clean itself with no small debris lingering on the cloth.
KeYoKe
i think this is what happened
images
is related to hand sweat/oil that causes permanent marks at the stainless steel pvd coating
i_am_fatimah
I hope apple bans you. First you return pro max for pro, then now return pro for another colour
KeYoKe
dont need ban la, just charge for the open box fee can liao :s22:
is because of such people thats why genuine cases which some people experience here, especially when is a brand new phone gotten from apple store, is not eligible for 1 to 1 exchange but only exchanged to a refurbished set (as mentioned from 1 of the bros here, though i got a 1 to 1 exchange at apple store due to some cosmetic issue)
argentinafa
images
Yah bottom is possible. But rag bro’s is in his mute switch button there. Very rare to happen there.
ragnarok95
Senior Moderator
Senior Moderator
Maybe my finger oily go touch. It's not very obvious but if you look carefully you can see half of the button got rainbow. But since its a mute switch, no way for it to cover up also. :s13:
Bought to apple store 2-3 guys also cannot see. Anyway, even if they see it, also cannot change cause i do not have apple care. :s13:
KeYoKe
Apple care can change meh :eek:
argentinafa
Nvm. Cosmetic issue for rainbow hue on space grey at such a small mute switch button is almost invisible. Easy to sell off.
We know you’ll change ur XS to 11 Pro soon too.
ragnarok95
Senior Moderator
Senior Moderator
Actually... i doubt so. :s13:
Already went to try the 11 Pro. Not much diff. Both are smooth as butter. Just that the camera on the 11 pro is much better. Which will also mean i need to top up a few hundreds just for that feature.
I think i will stick to my XS now, until there is a company road show then i see the price again. :D
