iPhone 5 Battery Life
EroNasubi
wah not normal
unplug my phone exactly at 8am
never turn off my push mail, 3 email account
this morning i did whatsapp
connect to wifi download an app, check instagram over wifi
check SMS
deleted some email
3G service is on, location service is on, wifi is on
BT is off
screen brightness at 60%
phone mostly on standby...
96% as of now.
From 8am till 1.40pm and your phone's battery dropped 4% nia??
You sure it is iPhone 5 you are holding? =:p
aLpHa-Ev7
Seems like Whatsapp could be a problem? i'm surprised they took so long to update to take advantage of the new iPhone 5 resolution. I'm speculating that there are problems with iOS6 and Whatsapp hence the update is taking longer than it should.
My gf's iPhone - morning left home with 85% (phone drained 15% overnight), reached office, took 3-4 pictures, about 5mins on Whatsapp, sent five photos via Whatsapp. Facebook abt 5mins.
At 2:56pm, left 29%. With LTE off.
Definitely something wrong.
Axela72
Even though starhub no LTE, make sure the LTE option is turned off. I would think that it would keep trying to search for an LTE signal even if there is none if the option is still enabled. Hence the battery drain.
May I know where is the setting to turn off the LTE? I check my iphone but couldn't locate the LTE option. only manage to find 3G option.
Thanks
fantasticfox
5h 10m usage. standby 15h 30m. 48% left now.
dropped 5% over 8 hours of standby last night. wifi and 3G on, BT and LTE off. whatsapp was in the background the whole time.
fantasticfox
Thanks
if you have LTE, it should replace the 3G option. does your plan have LTE?
Axela72
Oh, I didn't know that need to select plan with or without LTE. I just purchase the starhub 58/mth plan. I don't see any LTE option in any of their price plan. Thought all come with LTE as standard package.
rohitntu
I'm on LTE/Wireless mixed, several push e-mails going at the same time, several voice calls since morning. Brightness set to approx 50-75%.
Usage: 2hrs 11 mins
Standby: 8hrs
Battery remaining: 55%
I think the battery is a lot better than iPhone 4S. I can easily run it till the end of the day without charging whereas the iPhone 4S used to be in trouble by end of the day.
LTE is awesome on Singtel. The 3G spectrum is so crowded, it's impossible to use. Hopefully LTE doesn't go the same way. Hopefully the lower data limits will help.
mirukuboi
Phone drain 15% overnight is definitely strange. Mine is like a few % only.
nokeboi
Usage: 2hrs 11 mins
Standby: 8hrs
Agreed! and also LTE more stable, won't drop easily and full bar somemore. :s12::s12::s12:
fantasticfox
from what others have been saying, SH doesn't seem to have LTE.
Reborns
94%
i didnt really use the phone
*correction i did check my mail and deleted some mails
only turn on to check the time
and reset the password lock
so it dropped 2% over 2 hours
with everything turned on...
WIFI, Whatsapp, Push Mail..
and yeah my starhub doesnt seems to pick up LTE even i am in the middle of CBD
aLpHa-Ev7
Thanks
Settings -> General -> Cellular -> Enable LTE
Not sure if yours have LTE if on SH.
SomebodyThatIUsedToKnow
Battery life great here, Singtel lte. Even when it sometimes drop to 3G I don't disable lte.
And my friends say that you must charge 8h if not your battery life will suck but it's nonsense, really.
