iPhone 5 Battery Life
drpanda
Everyone experience is different. I am thinking whether it is io6 or iPhone 5 that causes the battery to drain like nobody businsss.. Some reported that after upgrade to iOS 6 on iPad and iPhone 4s and below, battery also drained
So it maybe ios 6 and not iPhone 5
You could be right, because after i upgraded to ios6 on my 4S, the battery drained quite fast than normal. iPhone5 battery life i would say still better than 4S.
cnt
u all hot adjust the scrn brightness lower abit? :s42:
youngblood
Not if it's me but whatsapp seems to be the key cause for my battery drainage. All those folks who have battery issues, I wonder if all are on whatsapp frequently.
Reborns
Mind posting a screenshot of ur usage? Your standby time and usage time? Thx :)
i just charged because i need to do support call..
*still in the office :(*
so the screen changed :(
this one is after i do a full charge cuz i anticipate a support call
i made the support call for the full 1hour and 12 minutes...
only drop to 86%
gdspd8
I strongly think it is whatsapp. Mine also using whatsapp with no LTE enable. Drain like siao.
My previous N8 is a complete joke when the OS is still Anna. With Whatsapp running, I can only use the phone for 2 hrs and complete flat. Worst is that the phone is really hot. After upgrading to Belle, the battery life is better.
gdspd8
Just now I fully charge my phone at 5.07am as I plug out the charging cable.
I check at 7.15am, left 96%. 4% drop in approx 2 hours.
Charlie_Zhang
Slept around 11pm at 93%, wake up late only 86% ....
Notice my new ipad battery also draining fast after the new os update... Fug
redevils
Please take note that signal coverage is important, if the signal is weak, battery will tend to drain faster which is normal. I have done some simple test on my iphone 5.
m1 user here
Day 1 12am-6am, 100% full charge with 3G turn on (3 bar), battery drop to 94%
Day 2 12am-6am, 100% full charge with airplane mode on, battery remain 100%
Day 3 12am-6am, 71% charge with airplane mode on, battery remain 71%
crazypaladin
My battery life was ok. With moderate usage, surfing net etc, I can last the day with 20% battery left.
camoguysg
Hmm I am beginning to suspect whether those experiencing batt issues are the starfug sets? I am a starfug user myself and seems to be experiencing the same from most users here. Like one fellow suggested, could be due to the weak signal and hence our phone constantly search for LTE etc? This is because my friend on Singtel can have his batt showing 100% even with LTE on for half a day without any usage. End of the day still like 80% batt left compared to me left 30% with light usage.
Mine this morning 100% when removed from charger at 7.10am ... Now left 96% with just one incoming SMS. :(
palmtungsten
Read one of the bros mentioned.. Shall not bother too much of the battery life..
Use it happily and enjoy the phone.. Just bring along external battery (eg. Yoobao 12000mah ext battery) and cable for "extra power juice" anytime...
worldt
m1 user here
Yes, when I switched from ST to M1, battery life drops noticeably. Must be M1 have fewer base stations. No other issues with the switch though.
Reborns
i am Starhub user leh
and since Starhub dun have LTE
the iphone wont be searching for LTE la...
greentea123
92% - 10.03AM
85% - 10.29AM
I believe that whatsapp is the one draining my battery. Started using whatsapp at 10.03AM till now 10.29AM, battery drained 7%.
sandwicher
It's not the StarHub sets for sure. It's the StarHub service. The phone doesn't search for LTE, but struggles to find the immensely crowded 3G base stations. Sucks.
