- Dec 27, 2007
Just received my SmartDevil screen protector (borderless + alignment tray).
Hi bro can sic link for this?
https://s.lazada.sg/s.bzjUMHi bro can sic link for this?
I have Corning one and it covers fully which might’ve issues with some cases. I chose non Corning and non dust cover.Hi bro, Corning glass dust proof selection? Thanks!
Bro, Spigen no alignment issue, just that it cause bubbles during installation. Bubbles can be removed depends on your installation skills.Hi all, if the spigen ezfit got alignment issue, what’s the next good TG to recommend with tray installation?
Personally, I find the Spigen Glas.tR EZ Fit to be dust magnet on the edges.
This can match Hoda or Zeelot?Just received my SmartDevil screen protector (borderless + alignment tray).
Never use those before.This can match Hoda or Zeelot?
Looking for recommendations on good MagSafe compatible iphone holders for my car, which are secure during driving.
I'm currently using a MagSafe Compatible Case with my Iphone.
Thanks.
Thanks.
Don't understand what you mean. I'm using Casetify case for my IP15PM and there is a cutout for the action button that allows me to use it to start camera app and take photos easily.: : PSA : :
DO NOT purchase CASETiFY case for iPhone 15 Pro series! It uses the old design that does not support Action Button! There is a cut-out originally meant for Ring/Silent switch.
He meant it should be a button and not cutout.Don't understand what you mean. I'm using Casetify case for my IP15PM and there is a cutout for the action button that allows me to use it to start camera app and take photos easily.
cutout is just lazy way out for most manufacturers.
nomad is one of e few leather case that has a button for the action button
Where you purchased it? Website show USD50Just wanted to share my experience with the NOMAD branded Iphone Case for my IP15 Pro Max.
It is MagSafe compatible and works with Magsafe Chargers.
My phone sticks very well and does not drop off a vertically positioned MagSafe Charger (Belkin).
It has an overall Premium Luxurious feel with a real leather back and all the side buttons are made of real metal.
There's 2 versions, the cheaper normal leather version at $59.90 or $89.90 for premium leather.
I purchased the cheaper $59.90 version and feel that it is not really that expensive.
Other MagSafe compatible branded cases such as Spigen can cost you over $50 bucks, and they are made of cheaper plastic TPU materials, including the side buttons.
This NOMAD case is made of real leather. All the side buttons are also made of metal.
