Boiijek
Out of curiousity, which screen protector do you guys think has the best oleophobic coating? I feel like I give most importance to that as I don't really damage my screen protectors
Rubick
personally i feel is flolab from my experience since the past
ralliart12
…I feel there is design flaw on the alignment frame that can cause bubbles. The frame cause the airflow to go multiple ways which can end up causing trapped air bubbles.
does the alignment frame have a last step where you slide an “integrated squeegee” across the whole length of the screen to squeeze out any bubbles?
Could it be there are some small dust particles present on the phone screen to cause the bubble(s)?
That step (& mechanism) is present on the Benks so that I gotten from 淘宝. I think it helps with regards to the bubble. Though ironically for some other reason I ended up not using the alignment tray for mine as well…
HZYiLong
Unfortunately not on the Spigen, I use Benks since iPX till iP14PM, zero bubbles.
Spigen alignment frame, before you “press and slide”, the glass already start pasting on one of the corners. Meaning when you “press and slide” in the middle, it caused 2 air escape flow, which end up trapping the air.
I can’t speak for those who failed installation, but for mine, I only encountered one air bubble that is not caused by dust.
ralliart12
I bought Mazer 3 in 1 MagSafe compatible wireless charging stand. So far tested on iPhone 15 pm, from 63% till 100% took about 2hr 15min (1415 till about 1630). Once connected to the MagSafe charger, iPhone screen shows the animation just like connecting to Apple MagSafe charger.
To me it is acceptable if I’m not in a hurry. Not sure what is the wattage during charging though I suspect it to be 7.5w. Understand Apple MagSafe charger able to charge at 15w.
https://shp.ee/2etm4v9
Any reason why you did not get the foldable one? Does this accept c-to-c cable or does it require USB-a-to-c cable?
ralliart12
Noted on the detailed explanation.
netzach
Feel like getting NOMAD o_Oo_Oo_O
tikokia
sharing some experience with magsafe charging
for the iphone 14 pro max 2022 i bot same time as my partner but she charge with lightning cable i charge with magsafe, roughly same usage everyday and charge once a day overnight
after close to 12 mth, her battery still 96% mine dropped to 88%
i think i will stick to wired charging this year
galvin
I think i have to agree with you on this.
I change phones every year. I used to use mostly Magsafe charging for my 14PM, and when i sold it off after a year, first time i got such a poor battery health of 90%. My 13PM and earlier iPhones fared much better.
Don't intend to use Magsafe for daily charging on my 15PM, except when i need to use my Magsafe battery pack.
Stoway
i have a Baseus USB C cable from pre-iphone 15. it does not charge my Iphone 15 now, any help?
leongws
Cause I don’t think I will be bringing it out. The foldable version got its usb port on the right side. The non foldable one is on the back.
It uses usb c to usb c cable, which is provided.
leongws
For my previous iPhone 14 pm, I’m using cables to charge and in 1 year the battery health dropped to 89%.
Usage and charging habit similar to all iPhones prior to iPhone 14 pm and only iPhone 14 pm dropped so drastically in a year. These issue are well documented and affects a lot of users worldwide. Therefore suspected that there is something not right with iPhone 14 pm.
Archuke
my iphone14pm, i charge 3 to 4 times a day due to heavy usage. 1 year later battery health was 92.
