LG G6
austy
Finally jumped the boat and bought a g6. Was deciding between s8 or g6 but went for g6. Disliked the curve screen which is useless and its a pain in the arse trying to find a simple glass screen protector. Saved myself around $300 too since s8 used sets are around 750-800 while I got my g6 used for 480.
So far the phone is awesome!
Carosell? With 98% good condition?
Sent from LGE LG-H990 using GAGT
aqualeris
Hi looking to get a G6 from street shop (Mobyshop etc).
Is the 2 year warranty still valid or claimable now if I get from a street shop? Thanks!
walkofwinners
Why get from shops? Just go carousell and buy direct from the owners.
If you die die getting from shops, market rate is about 650 to 670 for brand new sets.
aqualeris
Carousell is about 600 or so for a 1-2 month used set on average. Prefer to just pay another 50$ and have a peace of mind for a brand new set. Any idea which street shop has best price and is reliable?
Yes. 10chars
Thanks! Any idea how to register the 2nd year of warranty?
knreuben
Hi I'm planning to get a G6, but the only thing that bothers me is the screen ratio,can YouTube videos be played in FullScreen mode? And is Snapchat fully compatible with the g6, how are the pictures quality? Thanks
Bryson
As long as YouTube video playback are 18:9, it'll be full screen else they will be some black borders.
5408854088
Can share where to get that price of $650 to $670 for new set? Lowest I've seen around is $680.
Majima
any big issue for the G6 so far? like bootloop and such, planning to recontract my plan for this phone soon
batboyz
Is kinda annoying when it can't adjust the aspect ratio like the Galaxy S8 does.
G6 also has an app scaling option. You should try to use that. However, it's the same issue. There is always a caveat, since it may not work all the time depending on the app.
Audris
Has anyone tried charging the G6 with other mobile type C charger? I tried charging with Huawei type C charger and cable but it doesn't charge at all after 30 min despite showing the charging icon on the battery. It does ok with the original cable but thought of bringing just one set of charger overseas...
walkofwinners
Works fine for me. Using samsung fast charger with Samsung micro usb cable + Huawei usb c adapter.
