I heard is 30th may still very long...when the BTO is released, i'm sure this thread will be very alive once again...
sigh, ballot system very sian... u miss the previous one, next one u try, prices are higher and higher...
If in the previous BTO exercise, you got a q number and yr appt is in June, when you apply for this BTO exercise, do you indicate that you are applying in another exercise?
You can still apply for May BTO, if your q no. is far behind, if you select yr flat then you need to cancel application...You can only cancel once if not banned for 1year.
U already got appt to select a flat for previous bto? u r so lucky..but y still wanna apply from the May Bto? U'll lose out a chance for being 1st timer application. it will affect your chances when balloting. I applied for Mar sob but my nbr is so out of Q.![]()
How many from March BTO?
Thinking to join the March BTO but the prices was just too expensive ... but it seems like May BTO location wise is not the best of all... still thinking if should apply anot...
My parent is staying at SK but it is more than 2 km away ):
Punggol BTO is damn Ulu very inaccessible
SengKang's BTO is directly across the future hospital... people say feng shui not good...
Peeps any suggestion?
I think the release of BTO will be next week after the re-election...
2) a1vin1983 (from Clementi Ridges 4rm , march bto) resigned to fate ...help u create list la.
1) reddevil82 (from Clementi Ridges 4rm, March BTO)
Prices are ard like that these days, you want good location sure pay higher price... and i don't see them dropping any time soon...
Yup true doubt the price will drop in this 2 years...
btw anyone knows how HDB calculate the 2Km distance from your parent hse to the new site? Base on driving route or walking path?
(**Distance Quite different**)![]()
hmm or they take the map, then draw a 2km radius?
Thanks!!while waiting for my march balance flat selection, can i apply for the may BTO at the same time?
If I got a good number for may BTO, then I can forgo my march balance flat queue... Possible?
