[Mini OC guide] - EVGA X58 LE
darth_rufio
will some lower voltage later or maybe tomorrow. I see whether this setting is stable first. my realtemp quite funny. keep changing from 82 to 76 then 82 then 76 again.. my last i7-860 not like this.
ionicle88
what happend to your i7-860?
darth_rufio
I try the xmp settings but cannot even boot. then I try 7-7-7-19 but can only boot halfway. I want to set it 1866 so it's not wasted.
ionicle88
super interesting...
XMP profile u can only enable it unless u r on 133MHz BCLK
if u r running 200MHz, go for standard and change the DRAM Multiplier manually and iirc yours should be a 8-8-8-24 or 9-9-9-27
ionicle88
mine is 9-9-9-24 or 27.. cannot remember. so how to change the multiplier manually?
see my step 7 or something..
there is a Memory Frequency option that is on Auto... change that option will do :p
press enter and various speed will show up..
and the target memory frequency will show the effective speed on the multiplier..
that is also another plus feature on the EVGA boards... u don't have to manually calculate the speed :p
ionicle88
ok... will try.. now stress testing with 1.2562v. so far so good.
4GHz? thats the voltage i am running @ now.. GZGZ~~~ /clap
only jacked it up to 1.2875V for the article coz i know some chips may require more voltage :p
darth_rufio
yeah.. I also quite shock coz I try first at 1.26 then stable.. then lower abit to 1.2562 then still stable.. but my temp is around 81-85.
eurofunk
according to the others who successfully done it, supposed to get 70+ at load max and idle temp of 45max @ 4ghz....otherwise means somewhere nt done right liao...
