MyRepublic fibre - Part 4
Naoyuki
Wai new 1gbps plan have new network leh? Not just use same network as our current plan but just increase downlink and uplink only? :(
I remember reading that it's not just increasing down and uplink. Else it wouldn't make sense for them to make me wait 6 months for the scheduling. If your current speed is good it won't 100% make sure that 1gbps will be good for you especially with their latency problems.
wc1985
Will MyRepublic be allowing PS Now service to work with teleport? I'm in the beta but can't get the connection test to work seems like it's detecting via ip
ERT
[MR NOC] Fix the route to pan.baidu.com
Tracing route to pan.baidu.com [180.149.132.99]
1 6 ms 2 ms 2 ms 172.21.0.1
2 2 ms 1 ms 1 ms 40GE-103-6-148-45.myrepublic.com.sg [103.6.148.45]
3 2 ms 2 ms 1 ms newmedia.ge9-8.br02.sin02.pccwbtn.net [63.218.107.154]
4 2 ms 2 ms 2 ms ge9-8.br02.sin02.pccwbtn.net [63.218.107.153]
5 41 ms 37 ms 38 ms TenGE0-1-1-2.br03.hkg15.pccwbtn.net [63.218.210.162]
6 * * * Request timed out.
7 192 ms 192 ms 192 ms 202.97.61.125
8 193 ms 196 ms 225 ms 202.97.58.121
9 202 ms 199 ms 200 ms 202.97.53.37
10 198 ms 196 ms * 180.149.128.10
11 196 ms * 195 ms 180.149.128.134
12 195 ms 194 ms 194 ms 180.149.129.54
13 * * * Request timed out.
14 * * * Request timed out.
15 196 ms 196 ms 196 ms 180.149.132.99
Just Me
What's your point?
misato
I do hope that MR can control those nasty China Telecom folks but I guess it pipe dream at the moment to demand those lazy greedy sucker to do anything.
% Information related to '180.149.128.0 - 180.149.159.255'
inetnum: 180.149.128.0 - 180.149.159.255
netname: BJTEL
descr: ChinaTelecom Group Beijing Ltd,Co
descr: No.21 Chaoyangmen Beidajie,Dongcheng District,Beijing
country: CN
admin-c: YZ2206-AP
tech-c: HH1408-AP
mnt-by: MAINT-CNNIC-AP
mnt-lower: MAINT-CNNIC-AP
mnt-routes: MAINT-CNNIC-AP
status: ALLOCATED PORTABLE
changed: hm-changed@apnic.net 20090901
source: APNIC
person: Hongtao Hou
address: No.21 Chaoyangmen Beidajie,Dongcheng District,Beijing
country: CN
phone: +86-10-59504204
fax-no: +86-10-58503054
e-mail: houht@bjtelecom.net
nic-hdl: HH1408-AP
changed: ipas@cnnic.net.cn 20090831
source: APNIC
person: Yiming Zheng
country: CN
phone: +86-10-58503461
e-mail: zhengym@bjtelecom.net
nic-hdl: YZ2206-AP
source: APNIC
Tectrica
Does MyRepublic support IPv6 already? If yes, what settings should I set for my ASUS RT56U?
It has Native Static, Native DHCPv6, Tunnel 6in4, Tunnel 6to4, Tunnel 6rd.
Leaper_SG
My contract is ending on october and i'm confused whether to stick with MR or not after seeing so many complaints on the 1Gbps line. Currently on 100Mbps Pure, so far stable and good for past 2 years.
Off topic : Wheres the old team? Lawzer and the rest? Are they still with MR?
Visual_Gravity
My bad thought was down....
need some advise my opennet is in the living room i usually use my comp in my room, so i want the 1gbps is it better to do trunking of cat5 cable? or trunking all the way the fibre so that my ONT is in my room?
any advise?
shawniiex
any advise?
You use com in room, is wifi or lan cable.
Wifi cannot reach 1gbps afaik.
See which is cheaper if it's me, haha, should be a rather large price diff given it's trunking of different TYPE of cables.
ONT in room should be significantly more expensive and not worth it imo.
ERT
MR network infra suffering DDOS attacks from 2:25am.
Pinging 103.11.48.126 with 32 bytes of data:
Reply from 172.21.109.28: Destination host unreachable.
Request timed out.
Request timed out.
Tracing route to recursor1.myrepublic.com.sg [103.11.48.190]
1 * * * Request timed out. [supposed to be 172.21.0.1]
2 37 ms 2 ms 2 ms 40GE-103-6-148-45.myrepublic.com.sg [103.6.148.45]
3 5 ms 2 ms 2 ms 10GE-103-6-148-30.myrepublic.com.sg [103.6.148.30]
4 3 ms 2 ms 2 ms recursor1.myrepublic.com.sg [103.11.48.190]
ArleFK
I think Johnnny mentioned that they were busy helping the CSO team or something and didnt have time to come here
any advise?
Do trunking for Cat 6. Not advisable to move ONT so far from the TP
shawniiex
Request timed out.
Request timed out.
Received email saying Network under maintenance.
xRenol
I also received the following email sent at 1.13 am:
Dear MyRepublic subscriber,
Our network will be undergoing scheduled maintenance on 9 June 2014 between 2am to 6am. During this window, you may experience connectivity downtime lasting between 30 minutes to 1 hour. We apologise for any inconvenience caused during this maintenance.
Regards,
The MyRepublic Team
xRenol
any advise?
I think a cheaper option is to place the ONT in the living room and router in your room, then do trunking of Cat6 cable from living room to your room.
It is much cheaper to pull Ethernet cables than fibre optics cables.
lxXXxl
I from Jurong west also! Scheduled for 1gbps next Monday too! Asked them if all these disconnections were related to the upgrade they tell me they don't know :( hope I don't need to spend the weekend without any connection
Hope your installation goes well today! Together we'll suck the Jurong West MR fibre bandwidth dry!! :D
misato
Regards,
The MyRepublic Team
My connection suddenly went down around between 0715-0750. Had to restart the ONT before able to resume service. If its not an ONT fault then it means maintenance had overrun.
aSecret™
Hope so! Went without network connection since last Thursday. Pray they can rectify the problem today :(
xRenol
Did you manage to monitor if the connection went down before 0715?
I started using around 0800 and realized that my connection is down due to maintenance. I just restart my router and the connection is back. No restart on ONT.
