Note 2 battery life
gibson7
no.
i mean long standby time of a smartphone got no correlation to how much effective usage time is.
hence, when you posted your battery status screen capture initially...a few of us fellow forumers were asking for the screen on time.
because...although it's still an estimation...the amount time of screen is ON, we can estimate how much we had actually utilised the phone (usually when u use your phone...it's screen would be on as well)
kEvinErd
So you mean I must fully ultilise the phone for almost the whole day?
No you don't have to.. Different ppl have different usage patterns and thus different battery performances. But for your case, I'm just wondering why do you have blocking mode turned on even in the day..? You using that to block spam numbers or simply using your phone as a media player with no signal connections?
es0teric
The blocking mode is on all the while just that during specific time it will be block. So that's why it's block.
es0teric
no.
Actually have been using the phone much ever bought it. Only after next week exam then free to explore.
imreallyugly
any one got lobang for the original batter plus the desk top charger? battery not enough for one day. tend to watch too much movie. tia
i1magic
your phone just for show?
3.5hrs screen time when you ran the phone for 72rs...
seems like not using the phone at all.
This one is ultimate ... lasted 3days and screen ON time 6hrs+!!
xda-developers - View Single Post - Post Your Battery Stats
attachment.php
attachment.php
i1magic
Don't be so easily impressed, maybe he's an internal tester for mugen's 6400mah extended batt?:s13:
Seriously ... using that battery is like learning the skills from 葵花宝典 lor.
Kind of defeat the purpose. LOL!!
slo_mo
I unplugged my Note 2 from charger just before going to sleep and through "application monitor" I cleared all running apps and clear the RAM as well.
After 7+ hrs when I woke up my phone used up 20% battery life and highest consumption was "Phewtick" app. My app monitor still zero app running but when I check through recent apps the one when you press and hold home button Phewtick was there along with the other apps I ran before. I very sure nobody touched my phone during the 7hrs idle time.
So I think application monitor doesn't really close all the running apps. Anyone encountered the same issue?
curse154
Lost 20% after 7hrs doing nothing? That is not right at all. The most I lost for that long whilst doing nothing is only 3%.
Nemesismaster
As they said, Japanese is too sneaky.
