[Official] DVB-T2 USB/PCI-E/PCI TV Tuner Thread
cybertech
Will buying two TBS5220 USB DVB-T2 Sticks connecting to a PC can watch two different channels = Dual Tuner :s11:
Kiwi8
Deluxe Member
Yes. In fact, if the two channels are residing on the same frequency, u can even watch the two channels using a single tuner only.
Digital TV (whether be it by DVB-T2 or DVB-T or DVB-C) has this multiple-PLP function which allows all the TV channels on a selected frequency to be received by a single tuner.
Btw, I think if u are using USB stick on a PC, I do suggest u might as well get a PCI-E Dual Tuner for the PC instead. Leave the USB stick to be used on a laptop instead.
Kiwi8
Deluxe Member
yea, that's why asking for recommendations here mah.. if not i go buy the cheapest i can find liao.. lol :s13::s13:
The cheaper ones are likely to be non-DVB-T2-lite version (v 1.3.1), not able to receive the MediaCorp DVB-T2 channels which require the version 1.3.1.
Besides, at the lower price point u probably only get the older DVB-T tuner.
FatalityV
The 5220 is a product I highly reccomend based on my personal experience with it.
Other products I dont dare to reco because no experience with it!
sacredrays
Can I have the full model name? How much is it btw?
FatalityV
Kiwi8
Deluxe Member
But it's a pity u just missed the Halloween discount period.
However, if I'm not wrong, there should probably be a Christmas discount period, so if u can wait until then, then do wait. :o
sacredrays
oh.. that one. was trying to find something cheaper than that actually. lol :s13::s13:
ok, maybe I have to up my budget then. Thanks guys.
Kiwi8
Deluxe Member
I hope to get good offer during Black friday
When u buy, u got to make sure that the TV card adheres to the DVB-T2-lite (or v1.3.1) standard, otherwise it will not work to receive MediaCorp DVB-T2 signals, which use the standard.
As far as I know, BlackGold Technology company are the more prominent DVB card company in the US, but it seems that they do not have v1.3.1-compliant cards yet lor.
es0teric
I am looking at TBS5220 USB DVB T2/T
Do I need to check what you have mentioned? :s11:
Kiwi8
Deluxe Member
TBS is a China company based in ShenZhen, so their discount periods may not correspond to USA sales periods, though they may coincide.
es0teric
Oh btw
1. If I purchase TBS5220, do I have to check the specs you mentioned earlier?
2. If I would like to purchase during black Friday, what brand and model would you recommend?
Kiwi8
Deluxe Member
Oh btw
1) TBS5220 is already confirmed to be DVB-T2-lite compliant, and there is already forum user to confirm that it works.
2) What are u so obsessed with Black Friday, and must die die buy from companies participating in Black Friday promotion? Anyway, u can check with BlackGold Technology to see if they have updated their cards, or other TV tuner companies. So far I have not seen them update their cards to be DVB-T2-lite compliant.
LxIxVxE
Senior Mentor
Blackgold is UK one
Jan 2014 was told that their BGT3635 and BGT3602 support T2 v1.3.1
Not long ago they have launched another new card BGT3655 triple tuners which supports T2 v1.3.1
BGT3655 - BlackGold
But blackgold card quite expensive, can cost up to S$350 to over S$400 including tax and shipping
es0teric
Blackgold is UK one
BGT3655 - BlackGold
Then I guess I will purchase TBS5220. Or do you have any other recommend better than this?
Kiwi8
Deluxe Member
Blackgold is UK one
BGT3655 - BlackGold
Oh yes I made a blunder.... I forgot that when I tried the Blackgold purchasing platform, I noticed it was using UK and EU posting, so it is UK indeed. :o
I was put off by the big amount in postage for International mail. :eek:
