AsusEpoxy
looking for some thing to turn on my aircon via wifi can set timer etc...
is your aircon multisplit? what is the consumption like?
if u are looking to replace the remote control of the aircon, that's pretty easy.There is the xiaomi IR controller or popular broadlink RM Pro /Mini
If you are looking to control consumption and monitor energy usage, for single split aircons, you can use the SONOFF POW which can tolerate up to 16A of current.
If its a multi split system with higher consumption, can consider the Aeon Labs Heavy Duty Smart Switch using Z-Wave which can tolerate up to 40A of current.
Currently i have all of them
9N1Y9N1Y
Anyone using xiaomi remote? Can it work with Google home or xiaomi gt anything similar? I using xiaobai so call but AI but I need to press the button for it to work.
any advise? would like to grab a suitable 1 off 10.10 if in time
IloveEmma
Hi,
Any solution for 3 gangs switch?
I'm using livolo but it doesn't seems to 100% switch on and off all the time using broadlink. Also another negative it it doesn't report states. Thinking of changing to aqara smart switch but it doesn't have 3 gangs at the moment.
IloveEmma
Sorry for the many questions. Is it ok to short a switch, thus permanently powering on a smart light and just turn it on and off via automation? no safety concerns right?
pustefix
I think it is ok to hot wire the light but you must remember to turn off mains/breaker before working on the light. Another point is that if internet/router is down, you will not be able to turn on/off light.
Edwan@
Question, with all these blogs on, does it really keep the consumption in check ? From your experience
AsusEpoxy
it is ok, as you are just closing the circuit permanently. You might have some issues with pairing as some smart switches require sucessive on/off to enter pairing mode. You never know when they lose sync and might need a re-pairing.
AsusEpoxy
depends on your parameters that you set.
You can set aircon to on and off for a set amount of time everyday. Even if have remote control, cant do anything.
This is especially useful when you have immature tenants who do not stick to the tenancy agreements and use aircon in buffet mode.
LoneTraveller
The aircon companion is not really suitable for our environment as most of our local aircon power is outside connected to the compressor rather than inside the room. it is meant for those china style single unit aircon
Tks for the reply. I was thinking of using the companion plug to auto control the aircon as there was 1 time where i accidentally left the aircon running 24/7 for a few days...
ronnie_gogs
I bought the Yi E27 Philips smart lights (white) and they seem to only get detected if I am in the mainland china server, which doesn't work with google home. Any work around or region suggestion. Singapore region doesn't detect the light.
pajamasguy
You don’t need the AC companion. You can do the same thing with Xiaomi IR universal remote
Edwan@
Oh , this is interesting. So even if I off the RM pro, I can’t overwrite ?
boliao45
For simple on/off function, can consider the Aztech Kyla IR remote, essentially its orvibo IR cube rebranded for aztec, has GH integration. Easily available at challenger.
Sorry noob qn, any way to control my Mitsubishi electric starmex ac with phone ah? I have Google Home in place..
ihuazai2
