MaoZeDuo
Both rockers stop working. One switch for a fan while the other for a pendant of 3x xm smart bulbs.
Can it still turn on/off the lights by pressing the buttons? Both rockers dun work?
By any chance the lights you got the switch hook up to are also smart bulbs?
pajamasguy
That could be the problem. You cannot put smart bulbs with smart switch
This is according to Aqara tech
community.aqara.com/forum/faq-1/topic/wired-switches-lose-functionality-with-yeelight-bulbs-113
MaoZeDuo
I’ve read the link... according to the admin, the switch will be damaged over time if the lights are switch on/off with the app... but i only use the wall switch... and I also tried to hook it up in another wall to normal lights but still not working...
pajamasguy
Maybe it’s already broken so putting it somewhere else don’t change anything
MaoZeDuo
Hopefully broken and not just in “sleep” state cos i discarded it lol... anyway thanks for the link to be safe, gonna switch those smart bulbs to normal ones... have not been using its rgb anyway...
pajamasguy
Too bad, was gonna ask you to take some pics of the circuit board
Been wondering if there are fake or maybe second grade Xiaomi stuff out there.
I bought some Sonoff S20 plugs that doesn’t seem “right”
bullfrog
Hmm.. I'm using the xm w neutral switch with Osram lightify bulbs connected to them. So far so good. Hope it doesn't blow
coyote
Contrary to the notion of this thread, I'm going back to basic. Instead of getting wall mounted fan with remote control, I chosen to use those with only mechanical switch, those with a knob with 2 strings, 1 string for oscilate, string for fan speed. Sick and tired of loaing the remote control or it failing and rendered the fan completely useless. I already have air con for all rooms.
AsusEpoxy
but losing remote or remote failing are different matters leh.
9N1Y9N1Y
Anyone using xiaomi remote? Can it work with Google home or xiaomi gt anything similar? I using xiaobai so call but AI but I need to press the button for it to work.
jamie136
Using Xiaomi Honeywell smoke detectors. It can work on its own but better if connected to the mijia hub so that it can send you notifications
Thanks ya. May i know is Xiaomi smart home devices good? or i should use different brand of devices? I'm planning for home automation since going to renovate my house :)
theMKR
looking for some thing to turn on my aircon via wifi can set timer etc...
pajamasguy
For me it’s good. Others are having some problems with the wall switches
Using for about 10 months. I have pretty much all the sensors
