bullfrog
maybe try a better sd card? i dont shutdown hass.io
Ya. I installed hassio on a different card before restoring the snapshot. Wouldn't normally shutdown either but i was tidying up the mess of cables where all my devices are so kept unplugging.
Those of u running hassio, any issues when you unplug its power without shutting down nicely? I realise after doing that for a few times, my hassio became unstable. Suspect the OS file system became corrupted.
I took a snapshot of my config, reflashed hassio, copied back the snapshot and restored it.
Its stable again.
Looks like i have to treat it like a proper server and not anyhow unplug/plug.
if headless, how to do proper shutdown?
bullfrog
Same procedure as shutting down a Linux server remotely.
Ssh in, enter the shutdown command and run a continuous ping until i get a request timeout. Then i tell the data center ppl to power down the server.
Gotta do the samething here
The command to shutdown is
#hassio host shutdown
Ahh, wait, i see an option in the web interface to shutdown too. Guess i can also use that
:s13:
pustefix
Updated the calculation for bus arrival because round will round up the minutes, e.g. 1.5 -> 2. Use truncate instead so that 1.5 -> 1. Updated my original post.
value_template: "{{((as_timestamp(value_json['Services'][0]['NextBus']['EstimatedArrival'])-as_timestamp(now()))//60)|int}}"
Can shortcut the. Trigger??
:s13:
plustwo
cant seem to find the access key for xiaomi gateway in the mi home app
bullfrog
plustwo
raynerho
Hi all,
I just set up all my Philips Hue and linked them to my google home app. I also connected my Google Home Hub, which I purchased from US.
I tried to speak to google assistant on my Google Home Hub to turn on/off the lights but was unable to do so. Google Home Hub just keeps saying that it doesnt understand the commands. When I tried using the google assistant on the google home ios app, it works perfectly.
Can I know if anyone has a workaround to get Home Hub to work my Hue? I dont have the option of selection English (Singapore). Could it be because its a US Set, and thus doenst work locally?
Thanks!
bullfrog
yes, set to mainland. how to check if hk version? i bought from shopee should be china seller
I think, if you can connect to it while the app is set to mainland China then you have the China version gateway. Apparently the hk version can only be used when the app region is set to hk or sg.
Cannot confirm myself as i was able to get the key from my gateway. But i also refuse to update my gateway in case xiaomi removes the developer mode feature in their updates.
pustefix
Are you able to get to the about page? At the about page, tap repeatedly on the blank area until you see developer mode is enabled. The instruction HA refer to is wrong which ask user to tap on the version number. The HK version seems to have no about page.
Elon Jobs
Lazada ... i find their stuff more ex !
upgrading to home automation ex lol
mine started all bcos i bought the XM Robot Vacuum ... and found i could control via Alexa which had been sitting idle since BF 2017 !
lol and behold ... i started buying stuff that i have yet to open up to setup lol
a 2nd Alexa, Harmony Hub, and still to buy a Raspberry cos i wasn’t aware at that time Aqara cannot interface with Alexa & GH
Yes, slight more expensive, but consumer protection comes at the price. It’s a personal preference- to me I rather pay a 20-30% premium knowing that if I don’t get my item or it arrives faulty, I can get a full refund done in a matter of minutes through their app.
ksksksks
Under the recommendations of some bros here. Bought the rm pro. Superb device. Used it to control tv and aircon in the living room.
Got it cheap for $42 (after $3 coupon) here https://s.lazada.sg/s.XhUI and delivery was made to me in next working day.
sparhawk699
Hi,
Am new to home automation, just wondering what are the smart switches out there that do not require neutral wire? Thanks.
Just a newbie.
Toastyliving
Hi,
Just a newbie.
Hey, i've just created a guide for the simplest home automation method.
You can look at the steps here. Its about a 4 min read!
toastyliving.com/blog/simplest-home-automation-setup
If anybody is interested to contribute other methods of home automation or ideas, you can create a guide and i can post it on my website! I'm trying to aggregate home automation methods there.
sparhawk699
Thanks, will take a look.
sellun
What is the switch brand you are selling on your website?
Sent from HUAWEI BLA-L29 using GAGT
