Jas007
SONOFF RF BASIC
SHOPEE Flash Sale now on till 1pm
$5
remember to apply coupon if hooting >1
i bought 4 ! 🤣
pustefix
Just integrated the Xiaomi roborock vacuum in HA for zone cleaning. Now I can activate it to clean my room or the study or the living room. The hardest part is getting all the coordinates for the zone. The map saving mode in MiHome app is also a great feature, with it enabled, the map is not reset every time you start a new cleaning. You can also add virtual tape and no go zone to avoid problematic areas where the robot will get stuck. I was trying to setup Google Assistant so that I can say "OK Google, clean the study" but am getting the "couldn't update settings check your connection" error after adding the test app in Google Home. Anyone know of a solution?
zhihao57
Just started learning about smarthome, started by using Yeelights bulbs and lightstrip.
Recently just bought an Xiaomi universal IR controller to control my aircon.
In the mihome app, through the individual icons, I'm able to control my aircon successfully.
It all works fine till I try to include it in the automation.
E.g. I want the aircon to turn on along with my lights.
I created an automation, if lights turns on, aircon turns on.
I ran the automation manually, and the lights turns on, but the IR doesn't seem to work.
Any ideas? 😭😭!
If not this IR is just there to make my phone a remote. That's all. Rabak sia haha!
Inediblebulk
Any ideas? 😭😭!
Include a time delay after turning on the lights. The IR need time to initialise before all the remotes are available.
sparhawk699
Just wondering is Broadlink Pro+, a good hub that have wifi, IR and RF?...is there any other that is equally good out there?
Jas007
where’s the map saving mode in the app ?
can’t find 🤣
Jas007
just a word reg zone cleanup
if setting up manual zone clean up thru the app ... be careful your zonal box is not overlapping walls doorframes eg
some months back when the feature became available i played with it and on my 3rd zonal cleanup neglected to keep an te on the machine
i’d marked my boundary bigger than the perimeters of the room itself
the robot kept wanting to go into the corner of the doorframe, that plus there’s a recess cos transition between ceramic floor and laminated flooring
by the time i looked into what that sound was many mins later, i saw black soot-like material near the robot cleaner
tot wow it dug up all that dirt ... and then realized it was the wheel being worn out by friction 🤣🤣🤣
luckily it wasn’t completely worn out ... cos the wheels replacement aren’t cheap ! 🤣🤣🤣
pustefix
Thanks for the warning about zone cleanup, however I am doing it in Home Assistant where the coordinates are specified, so every time the zone is exactly the same size. Map saving mode is in settings, Vacuum settings and you'll find an option to turn on Map saving Mode (Beta) as the first item.
zhihao57
for my home automation, i'm using mostly xiaomi products. All of automation scripts are controlled via homeassistant and not via mihome app. These are the pros of using homeassistant instead of mihome app for automation:
1. The automation are store and executed locally. They can still be executed if your internet is down.
2. You can consolidate different brand of products into homeassistant and you can create automation which executes actions across different product. For example, you have a xiaomi motion sensor and a tp-link wifi smart switch. You can use homeassistant to turn on the tp-link smart switch if a motion is detected on the xiaomi motion sensor.
3. Security. As all the info are stored locally and not on the internet.
4. Speed. You may notice some lag if you use the mihome app automation to trigger actions. However, it's almost instant with homeassistant as it's local connection.
5. integration with alexa and google home. You will not be restricted with products not compatible with alexa/google home. Once a device is added to homeassistant, you will be able to control it on alexa/google home via homeassistant.
BUT, You will need to host/run homeassistant 24/7 in your home network. i'm running homeassistant on docker on my synology nas. You can also run it on respberry pi which is super light weight and does not consume a lot of electricity....
Any comprehensive guides for this? Does this only work for Xiaomi products? How about aqara's?
The lag in mihome automation is sort of killing me slowly inside 😭.
SaLvAtoOo
The lag in mihome automation is sort of killing me slowly inside ��.
works for all the product in the xiaomi ecosystem including aqara and a lot of other brand smart devices. Visit home-assistant site to check out more.
https://www.home-assistant.io/ has a lot of examples and guides.
Jas007
ios Mi Home App
settings —> Vacuum Settings :
• robot’s time zone
• voice pack
• volume settings
• DND Mode
mine’s always been like this since i updated the app once or 2x since ...
time is set to SG ...
iirc, setting to China also same options
i don’t have the map saving feature ...
maybe it’s bcos mine is the non-mopping version ? (but can’t be since using same app)
pustefix
ios Mi Home App
• robot’s time zone
• voice pack
• volume settings
• DND Mode
I am using Gen 2 (with mopping) on SG server, Android. Maybe others can confirm for Gen 1.
Toastyliving
any kind soul wanna help in creating a guide to set up step by step with home assistant?
Their website seems pretty intimidating for beginners.
I can help to list the step by step if anyone is willing to make it!
toastyliving.com/blog/simplest-home-automation-setup
zhihao57
Yeah.. feels like I'm gonna spend a long time analyzing the whole thing hahahah!
