any kind soul wanna help in creating a guide to set up step by step with home assistant?
Their website seems pretty intimidating for beginners.
I can help to list the step by step if anyone is willing to make it!
toastyliving.com/blog/simplest-home-automation-setup
Normally RF remote have different channels and can send many different RF signal. My RF remote have 80rf signalsnoob qns. is it correct to say that each rf switch comes with 1 remote? so if i change to rf switches for my whole house, potentially i will have 10+ remotes lying arnd?
The Xiaomi water leak sensor can be used as a rain sensor now
I got it from aliexpresscan SIC link to buy the external water sensor?
show inside pls.. need to know how you solderThe Xiaomi water leak sensor can be used as a rain sensor now
wow close the window also?The Xiaomi water leak sensor can be used as a rain sensor now
Yupz, the rain water will still come in but restricted around the windows area. The blinds should prevent the rain from splashing further into the room, onto my sofa or TV.Just curious. But how does closing the blinds keep rain out if window is still open? Wouldn't water run down the blind and drip into the house?
Posted from PCWX using Me dic stinks
No soldering needed. Just unscrew the 2 screws using allen key and connect the wires.
Yes, tested and workingHave u tested it before? Does it works?
It's a "raindrop module" to detect rain.
Haa...you'll need to motorize your windows first...or you can setup a reminder to close the windows when it's rainingwow close the window also?
how you know which side to connect the +/- wire? btw i bought the rf module you recommended, how to connect it to the gate remote? the voltage will be different right?![]()
You can connect either way, don't really matter as you're connecting a switch.how you know which side to connect the +/- wire? btw i bought the rf module you recommended, how to connect it to the gate remote? the voltage will be different right?
