plustwo
You can connect either way, don't really matter as you're connecting a switch.
For the IR module, connect the gate switch contacts to the "normally open" (NO) pins on the relay.
the ir mod shows that max output is 10a and the rf remote uses a 23a battery. do i need to adjust anything?
iceJman
23a is the battery model...not the battery's power rating so u don't have to do anything. The IR remote uses it's own 5V power.
seianko
Suspended
Just started learning about smarthome, started by using Yeelights bulbs and lightstrip.
Recently just bought an Xiaomi universal IR controller to control my aircon.
In the mihome app, through the individual icons, I'm able to control my aircon successfully.
It all works fine till I try to include it in the automation.
E.g. I want the aircon to turn on along with my lights.
I created an automation, if lights turns on, aircon turns on.
I ran the automation manually, and the lights turns on, but the IR doesn't seem to work.
Any ideas? ����!
If not this IR is just there to make my phone a remote. That's all. Rabak sia haha!
becos IR is just a signal. ur hardware needs to have the inbuilt "software" to send a signal to the lights mechanism to follow the same. usually such is a internal hardlink or run thru another communication protocol
seianko
Suspended
Anybody knows how to convert a standard light switch with the circular tube light to be wifi enabled? I want to switch off my light from my bed :o
u need to buy a switch plate, with the switch mechanism to be able to program w ur phone and receive instruction via wifi aka tcp/ip
bluetooth works as well not necessary wifi
bullfrog
A few options but since there is no neutral wire at the switch by default, u can get a broadlink RM Pro. Then replace ur light switch with a broadlink tc 1 switch.
U should be able to control ur light switch via alexa / Google home or with ur phone. You can also on/off it like a physical switch.
Posted from PCWX using Me dic stinks
plustwo
no wonder!! do you know what's the keyword to search for if i'm looking for a usb to 5v adaptor that fits nicely on the 2 pins on the ir module? prefer not to destroy a usb cable for it
seianko
Suspended
retrofit. like u say limited options
The options in singapore market is very mixed and messy. doesnt actually offer 1 stop solution. its all very surface automation. an interface that is purely based on wifi isnt any energy efficient
pig@@gie
My electrician quote me 1 no neutral point instead of individual neutral wire charge, any kind soul possible to advise me wat is the difference between neutral wire and neutral point?
skyver
Recently I bought a raspberry pi 3b plus and I tried setting up Hassio. No matter what I tried, I can’t access the hassio webpage. I tried setting static ip for the pi and access it using IP:8123. Still cannot. I can ping it though. I really don’t know how to proceed already. Anyone able to help me??
SaLvAtoOo
can share the exact link of the hassio u downloaded? Download the 32bit version here.
assume u set the static ip via MAC address reservation on your DHCP and the ip address is correct??
how long did u wait for the installation?
confirm u not on proxy or vpn?
not sure if it helps, did u try to connect a HDMI cable and see if there's any error output?
try a diff SD card....
SaLvAtoOo
i'm not sure, but i guess 1 neutral point meaning he will pull just 1 wire.. and split from there? instead of pulling multiple neutral wires from the breaker?
SaLvAtoOo
how about xiaomi no neutral switch? although it has a high failure rate. haha
the broadlink way works as well.. but u need the RM Pro and make sure that the RF signal can reach all the TC switches...
bullfrog
Recently I bought a raspberry pi 3b plus and I tried setting up Hassio. No matter what I tried, I cant access the hassio webpage. I tried setting static ip for the pi and access it using IP:8123. Still cannot. I can ping it though. I really don't know how to proceed already. Anyone able to help me??
Connect a hdmi monitor to it and power it up. You should see it starting up. Any errors will appear too.
However, that's really strange since the correct image for the pi should not have errors.
Ya, the sd card may also be the cause. Try a different one.
bullfrog
can share the exact link of the hassio u downloaded? Download the 32bit versionhere
I concur too!
seianko
Suspended
neutral point is a star configuration, incoming down all down
and then depend how he does the single nodal neutral, as in where he located it.
cons, any issues, u hv a hard time troubleshooting which one uplorry. Most establishments would go for this mode. #cheaper,better, faster
(better as in is for installer pov, save trouble, earn more money)>> in ur case, ur electrician trying to save u $
individual meaning, each device will have a neutral cable to run back to the mains.
Cons, cost more
Pros, u know which one is down from layman pov. For some appliances, it is recommended practice
For old retrofit homes, i will say go for separate node (point/jn box)of neutral. so that u know when it goes down, u know its the new one or old one. BUT there can be huge difficulty in installation -- space
//one answer per day quota is up :D
plustwo
anyone have issues with xiaomi gateway not showing up in ha? even under configuration/integrations page there's no xiaomi to configure
SaLvAtoOo
used to have this problem with certain version of gateway. that's why i dont anyhow update the gateway.. haha..
which version is your gateway on? 1.4.1_161.0143 is mine...
plustwo
164.0158.. previously was 161 something but couldn't detect already, accidentally click update while playing around trying to find solution..
edit: i can see all the sensors and can even control the gateway light but i cant find all the yeelights connected to the gateway
