OnePlus 8/8 Pro!
Aikon
OK thanks I have one similar but is baseus does not work for 1+
This is crazy now my baseus mange to work
Is it working fine now bro? Actually the oneplus 8 pro is not as fussy as the new Samsung phones.
https://www.hachi.tech/android-zone/phone-accessories/cables/elecom-usb-type-c-to-audio-35mm-silver-ad-c35dssv--4953103367661
I even bought this Elecom for my note 10 which didn't work but is fine on the OP8 Pro.
Aikon
Is there any type c to 3.5mm that come with the charging port?
https://www.hachi.tech/accessories-showroom/mobile-accessories/cables/elecom-ad-c35cbk-usb-type-c-to-audio-35mm-with-charging-blk--4549550107105
Elecom also has this version with the extra USB c jack.
KeYoKe
Hi pros here, i'm thinking of pulling the trigger for Oneplus 8 Pro. I see some sellers on Lazada with export set selling only $100 cheaper but lose warranty. Is the Official store the best place to get?
Thanks in advance.
U have to weigh out if u want 1 year peace of mind for $100
hoks
Thanks in advance.
Its more than 100 cheaper leh. Some r as low as 1150 for 256gb version.
Side track, may I ask what's the conclusion with the mrt Google pay huh? So far it's working for export sets but not local sets?
igarashi
my not working lazada set.
stonelips
Apparently so. Lazada set as well
Aikon
those working using Gpay or Gpay Singapore ?
Local set. Just tried to use this on public transport. Couldn't detect at exit. Very fussy. Works fine for retail though.
Will probably sell this back to Mr Mobile. Disappointing.
igarashi
Just tried using it again in train. Not working it just say it didn't work. Same so feel like selling it away...
hoks
Yeah dis gpay mrt thing is holding me back.
Huawei no gms. Find x2 pro no wireless charge and batt life questionable. Samsung exynos cmi. Buy one phone so difficult :)
Kitaro9202
I seldom take mrt but I try it also cannot detect zzz
Kitaro9202
After i reboot my phone everything seem to work fine lol
suxalot
Works fine for me.
The combination is to first go to developer options and enable non-standard NFC Tag support. Also use Google Pay, not Google Pay Singapore. I deleted the latter.
kryptonit3
Works fine for me.
nfc tag option does not work. tested both combination before even reset device. only not tested is wipe off the base rom and reflash it..
