PC rig Building/Upgrade again
Vanyel
And try and get those GPU with silencing. The gpu and all the fans will spin like crazy, really like helicopter. :(
ok lah noise
i not very sensitive type, my speakers always very loud when gaming
The_King
my rig on good old fan coolers ^^
personally i dun find the AIO coolers to be more cost effective than normal fan coolers
anything wrong, just change a fan
but if pump spoil? gg?
same, prefer heat sink, i dont like to check every one and then for leak
perfer install and forgot type until 2 yr later to clear the dust
Vanyel
Whole system i think can consider armaggeddon, i find their items are pretty value for money
https://armaggeddonpc.com/collections/radeon-rx-9070xt-pcs
Their aftersales are quite okay and u can customise.
They are the authorised seller for inno3d, so they definitely has the price and support advantage for the gfc
using 13600kf atm, think its still decent enough no need to change
but ya their pricings seems decent~
justln
justln
I just had my first custom pc done by aftershock-
AM5 9700x w/ AIO
Asus x870e proart 10gbps
5080
32gb ram
2tb sdd
850w
Lianli o11 dyanamic evo xl
10 fans
Deliver just last week, migrate my hdd + ssd.. their services not bad already, install alll swee swee!
Wah, mine is 4.2k, Mansa.
Motherboard: Gigabyte B850 Eagle Wi-Fi 6E & Bluetooth
(DDR5)
Processor: Ryzen 7 9800X3D
Cooler: Thermalright Phantom Spirit 120 EVO
Graphics Card: Zotac RTX 5080 16 GB (Solid OC)
SSD: Lexar NM790 2 TB Gen.4 - R:7400/W:6500
RAM:Adata RGB XPG Lancer Blade DDR5 32 GB 6000
MHz - Black
Power Supply: Seasonic Focus GX 1000 W 80 + Gold (Full-
Mod) (V4 ATX 3.1)
Case: Lian Li Lancool 207 - Black
Operating System: Un-Activated Windows 11 Home 64-Bit
rEe_TaN
(DDR5)
MHz - Black
Mod) (V4 ATX 3.1)
Nice. Mine expensive because mobo, aio and braided cables plus vertical gpu mount. Am using the same brand gpu as you.
If i use fan, i think within 7 to 9mths sure have dust trapped at fans liao.
Currently gpu seats at 31-33 celcius and cpu is at 47-52 celcius
Vanyel
saw a ASUS Prime Radeon RX 9070 XT OC at $1269.00
worth it bo?
or get a 2nd 9070...everything so overpriced now...really jialat
The_King
testerjp
Now then i realise IT show, honestly ,prices today are like 1/2 or 2/3 of covid19 times.
And at alot better performance.
Vanyel
haizz...think i hoot the asus prime oc 9070XT for elder boy pass the 4070ti super to the younger and then the 9070 pulse on my own...
Vanyel
i couldnt get the 9070 non XT into my PC casing lol
my tabao casing probly wont be here anytime soon
went to cut an opening :ROFLMAO:
but ok lah, cant tell tell right after fix back the cover?
will have to do for now until new casing comes haha
