PC rig Building/Upgrade again
eq2addict
its just casing fans and psu
plus there's been thousands of purchases from the shop already
honestly between Taobao and our shopee lazarda, i personally feel its easier to get refund from Taoabo if anything goes wrong
there's this fake seller with 0 sales on shopee and lazarda using other shops pictures for so long until today still not banned
*dun agree with ur local china made quality is HIGHLY questionable part
look thru everything in ur hse and see whats made in china
problem is lazada very hard to see the seller name.
the UI dun emphasis the seller name unless the seller put the name in the picture ( which all the scammer will kope)
Vanyel
Can I know when you buy GPU, do you open to check the GPU for physical damage or if it sealed etc...
If yes before or after paying
Thanks
actually if from shop so far no
but from if used gpu, carousell had 1 bad experience b4
heavily mined 3060ti, the thermal paste melted dripping inside got stains when i took a closer look at home
but luckily got warranty, wentto asus agent they replaced me 4060ti because 3060ti already no longer in production i think
but generally a guide would be to check the shops reviews/rep first
The_King
Thanks me go SLS ssrr this weekend
The_King
buying simi?
honestly check online with them or call first
when u confirm getting then go down
no need waste time there
looking for simi gpu?
9070xt
Me going to PC show, then go 4 horse road and then SLS
Since all nearby might a well one shot
Vanyel
9070xt
i think 1k-1.1k might be hard to find liao
i pm u the shop i got from
give u headsup, raytracing still nvidia better, DLSS > FSR
i regretted not buying 4070ti super x2 last yr at 1188 price
The_King
Thanks, me 8 or 9yr nv buy GPU liao
Don't know the market price but I know now GPU super expensive
Vanyel
Came in ^^
coyote
Now amd or Intel cpu better?
I still using amd 3600
I just bought some i5 9400 and i5 10400 OEM pc off carousel... All do not have all those bells and whistles listed in TS's chassis spec...and they worked equally well...
$280 spent mostly on cosmetic features...
Vanyel
$220+
I didnt get their aio, would prefer to stick to aircooler
Well i had to change the casing, coz after adding in the 9070 my mhw temp will spike to 90+
Its a psu and cooling upgrade too not just cosmetics
coyote
Kk time to start work ^^
I am like looking at myself 15-20 years ago... With work, kids and stuffs, I just buy desktops off carousel to minimize the work needed. I can still swap parts around very fast but tried to minimize the work needed... I have like > 10 computers that I helping my siblings families to maintain...
Vanyel
Ok lah, not all at a time so not that xiong
I upgrade my kids pc 1 at a time too and slowly shift the parts around in my hse
Have 6 working PCs at home currently 😂
