POCO X3
blade39
Anyone facing issue with micloud?
It started having problem to sync and backup app data, eg: Note, Recorder, Call log etc...
Find my device deactivated.
Started since around Aug 9
Read HWZ Forum Rules!
guyz92
My X3 NFC finally going through hospice care. Battery bloated and it doesn't charge anymore.
my battery down to 35% and I have it on ultimate battery saving mode. hopefully it can last until my new F4 arrives.(shopee say will deliver by 19th :cautious:)
My Poco X3 NFC started to show similar issue.
The battery can't be charge using USB-C to USB-C cable.
Need to use USB-A cable to charge.
The bottom speaker near the USB port stopped working.
Plugging the phone to PC via USB-A to USB-C only able to charge the phone, PC can't detect the phone.
Most likely my Poco X3 NFC days are numbered.
Gonna find a way to migrate the data from this phone via WiFi before it is too late.
highdiver_2000
Clean your usb port!
swathe
Found a shop in Chinatown, charging $45.
Official service centre is 50% more, worth to save the money?
kazuki666
Anyone using X3 Pro installs and using the simply go app? I noticed past few days it will keep crashing and force my phone to auto reboot
hkchew03
Happen to some phone on some firmware, had this issue on my 12s Ultra EU ROM, but still able to use the card on bus as a simplygo card.
kazuki666
I checked the review of simply go on play store, and there are actually quite a few reviews that say the same crashing thing. Lucky there is the ezlink app which is able to do most of the same functions as simplygo
But it is annoying why the app keeps crashing
