POCO X3
rathalos
i would suggest testing writing the sdcard full using the phone then reading stuff back.. can insert the sdcard into phone and phone can recognise it is not an assurance.. the phone may not be able to write to all 512GB of it..
plus, be careful of sdcards nowadays.. 60% of the cards sold online are FAKE, with reviews all blissfully unaware of how to test the cards..
i suggest u guys to download h2testw and test the capacity and R/W speeds of the card to make sure you arent duped.. i encountered a few times of fake cards..
justln
Yua Mikami
Never buy cases with finger grip cause that's the weakest spot that breaks easily. Just buy normal Silicon Case + Finger Grip and replace if needed.
lesson learnt
i bought it because at that time only have case that comes with a finger ring and claimed to be anti-shock...
Shutterbox
On paper, xiaomi states up to 256gb i believe. Better check properly first before buying 512
Hybrid SIM slot, nano-SIM + nano-SIM or microSD
Up to 256GB expandable storage
Supports dual SIM and dual VoLTE
Is there a adaptor to use both sim n microsd card?
johnnyboi
btw i notice the lags and choppiness mentioned when playing ml happens when playing chess mode when the animations lag spike the game :s13:
justln
Remember got people say it's because the framerate is dipping down a lot when the phone detects "inactivity" to save battery, when you swipe then the framerate goes up a lot, resulting in choppiness.
Probably need other apps or even ROMs to solve the issue.\
I used the nano SD card adapter, 4G works fine but quite irritating cause the tab comes out of your SIM tray area and you have to fold the adapter back, cover with case.
rathalos
have those who say framerate is dipping tried switching over to 60hz mode and see if the framerate dip issue still persist?
