[Printer] Laser Printer questions lip lai !!!
Ashana81
Didn't go through the entire thread. Have not used a home laser printer. Would be great if you can help with the following questions.
Any recommendation based on the requirements below?
Work use
Would need one able to print on fabric, heat transfer paper and photos.
1. Mono or Colour
Color
2. Print, Print Scan Copy (3in1) or Print Scan Copy Fax (4in1)
3. Printing capacity per month
Varies. Can consider 50-100pcs/month.
4. Budget
Best if less than $350.
5. Other extra requirement like wireless, iphone printing etc.
Don't necessary need wireless printing.
Best to have separate ink cartridges for each color.
Low ink cartridges cost
Reasonable cost per print. Looking at less than 50 cents per print.
Casual use
Not printing photos. Mainly color/BW document printings.
1. Mono or Colour
Color
Varies. Can consider 20-100pcs/month.
4. Budget
Best if less than $200.
Reasonable cost per print. Looking at less than 10 cents per print.
Thanks!
Columbian78
Anyone with laser printer questions can come in and ask !!
Currently in the market the top 3 brands are Fuji Xerox, Brother and Samsung.
List the specs of printer that you are looking in this way so hwzers can assist you better!
1. Mono or Colour
Mono
3in1
Only occasional printing (less than 100 per mth)
4. Budget
Less than $300
Wireless, duplex (double side printing?)
Reliable if I don't print often.
Cheers !!
Thanks, please recommend.
Aloeus
I'm looking at Xerox M255z, is this my best option considering my requirements below?
1. Mono
3. ~200 pages / mth?
4. Need duplex printing? Yes
5. Need duplex scanning? No
6. Wireless
TrueB1ue
I need a mono laser printer
I need print scan copy
I need auto duplex scanning (auto feeder max how many page)
Wireless without the need to go thru a router (optional)
toner price?
anyone can advise?
Firestone
My printer arrived... Da fug... the box is 1/2 as tall as me..
the TV is 32" in size...
mfeOnline
1. Mono or Colour
Colour
3in1
4. Budget
Less than $500
Wireless a must,
and able to use compatible toners and low maintenance?
tonerseller
Work use
1. Mono or Colour
Color
4. Budget
Casual use
1. Mono or Colour
Color
4. Budget
Thanks!
Work,
I cant comment much as I am not knowledgeable about T-shirt heat printing. This is what i found for you thou.
Best laser printer for heat transfer - T-Shirt Forums
Seems like OKI is the preferred choice.
Home,
Cheapest is Fuji Xerox CM215b $399 + $80 Ntuc vouchers
Original colour is 25cents
compatible colour is 12 cents
tonerseller
1. Mono
6. Wireless
Just go for M255z. It is the best in its range already.
tonerseller
toner price?
anyone can advise?
Canon MF4890dw $499
CRG-328 $102 2,100 pages
weiyang76
toner price?
anyone can advise?
thanks....any other brand or cheaper model?
Looking at abt $399
really hard for your requirements honestly.
cost is the cap for your decision. then you should sacrifice on some variables like duplex function, wireless capabilities without router, or even having no network capability functions.
the closest to your requirements would be a inkjet printer that can do colour printing as well. it goes around $150-$250. i am guessing you are using it for home purposes and mainly yourself and one other user. inkjet will suffice mostly.
if it's for business, i suggest you buck up the prices to $490. samsung has some models that support what you need.
Yowzer
Xerox has the best image & color reproduction using original toner. Can see a drop in quality with compatible toner if viewed closely.
TrueB1ue
Actually my main aim is on the duplex scan ....the rest I really don't need.
Since I have a inkjet that why I thought of getting mono laser for a change.
If getting inkjet model with duplex scan, anyone know what model have this function?
tonerseller
Dont bother Samsung. The model would be SCX-4833FR which is EOL all the dealers are just dumping stocks away but they cant clear all. Their toners are non-existent at your convenient as their have supplies shortage.
Just up to $100 or buy Inkjet. That is $499 is the cheapest already. This features are niche. For HP, the printer costs $799.
For Fuji Xerox it costs $499 also but no wifi.
Hope you understand that there is not cheaper models avaliable already. Either you up your budget or reduce your requirements :)
tonerseller
Canon MX897 (within your budget but dunno EOL already or not.)
klein_8888
looking for colour laser printer
need printing function only.
wireless is bonus if price difference is not a lot.
looking for value for money ones.
TrueB1ue
For the wireless function, does it still need to go thru a router which my previous canon model required one. Wonder new one can go direct?
tonerseller
Fuji Xerox CP205. $259 their usual price is $399.
Now promo + $50 ntuc vouchers + 1 black toner + wireless router
toners
Black $95 2k pages
c.m.y each also $95 each and 1.4k pages each
