[Printer] Laser Printer questions lip lai !!!
tonerseller
hi all, need some advice.
currently using a brother hl-2270dw for about 3 years.
the print isn't uniform, like have a few streaks of faded print across the page.
What should i do? I just changed the toner very recently. no lights flashing also.
You try take the toner out and shake left and right. If still cannot means ur drum spoil le have to change
tonerseller
Hi Guys,
I am looking for a printer and hope someone can recommend a good one.
1. Mono or Colour
Color
2. Print, Print Scan Copy (3in1) or Print Scan Copy Fax (4in1)
Just printing
3. Printing capacity per month
50 pages
4. Budget
100-150
5. Other extra requirement like wireless, iphone printing etc.
No frills needed. Just need basic printing with affordable consumables
USB only can ah?
Fronsac
I am currently using Fuji 255dw and very satisfy with it except it is very flimsy especially the tray which I manage to break it today. Would it be economical to repair it since it is like 2 years old, or if I buy a new one is there anything that is similar to this model but sturdier? I just need networked b/w duplex printing with scanning ability, lots of text printing so if the print out is sharp will be a lot better.
known2014
Hello all, where is a good shop in north area or funan to buy home laser printers from? I want to print and scan, monochrome. No need wifi or fax or auto duplex. Thinking of something similar to Fuji Xerox M215b.
I have a older Fuji Xerox, any shops take trade ins?
Cpt.Murdock
Hi! Can advise me a laser printer model based on the following needs?
1. Color
3. Less than 600
4.cheap consumables, wifi connectivity, duplex
Able to let me know the mono option too?
Cheers !!
Veron4
Hi guys, is there any fair for fuji xerox laser printer anywhere in sg?
laptopseller
Hi Tonerseller Bro,
I have been using the MFC9140CDN for the past few months and I like it however recently needed to print some A4 Glossy labels which happened to be thicker than the normal paper and when I print it, the label (whole piece) becomes crumpled and there's abit like burning smell from it. Is there any way to solve this issue? - Other than not to use the A4 labels.
If not, which printer would you recommend for my requirement?
1) MFC Laser Monochrome
2) No need network
3) Printing thicker piece of paper without problem
4) 3rd party toner option (cheaper printing)
5) usage is around: 4k pieces a month
Thanks in advance,
zoossh
Then in terms of longtitivty which one is better. I dun wan to handle jammed papers
Welcome to the laser club. Once you used laser, no more turning back to the money sucking inkjets.
No wifi (USB connection only)
Mono
Fuji Xerox M215b $159
Brother DCP-1510 $148
Color
Fuji Xerox CM215b $399
With Wifi
Mono
Fuji Xerox M215fw $239
Brother MFC-1810 4 get price
Color
Fuji Xerox CM215fw $499
IF you want cheap consumables then go for Fuji Xerox cause brother you still need to change drum on top of your toners. Fuji Xerox dont need.
Globe
guys, anyone knows if there are still any AIO that can scan 35mm films ?
Canon used to have them but it stop production.
1. AIO
2. can print up to 300gsm paper
3. scan 35mm film
4. graphics printing (name cards, phamlets)
Mugentis
hi guys, am looking for a laser printer with the following specs:
1) B&W
2) Duplex Print, duplex Scan, Copy
3) Auto duplex with ADF
4) A4 only
Amekaze
Hi,
Have a question on the Fuji Xerox CM215fw...
Does the document feed allow for duplex scanning at all? Either automatic or manual?
Or are there ways that two-sided scanning can be done via any software?
Bargainhunter56
1. AIO
3. scan 35mm film
Cannot find AIO that can do film scanning liao lor. Last i heard la
awayaway
zz fuji m215b causing me problems.
says paper jam but there's no paper jam at all.
i suspect is dust/toner buildup on the roller but it's not like i can open it up and clean it.
now have to bring all the way down to bukit merah
Mr_woW5
Hi Guys,
1. Mono
2. Print Scan Copy (3in1)
3. Wireless and duplex printing
4. Cheap consumables.
Thank you for your help! :)
