[Printer] Laser Printer questions lip lai !!!
tifosi
Can i get advice on a color laser printer that can do edge to edge aka borderless printing? which models you recommend for great picture quality?
failing which, how about a color inkjet recommendation? i read the hwz review on the new maxify models and the print quality is a tad underwhelming. wonder which models are recommended for a4 borderless color prints for brochures.
thanks very much everyone
marsbarsz
hi all. could you advice which is the suggested model i should look for glossy and matte prints? thanks in advance!
Rknight
Hi guys I am looking for
1. Colour laser printer
2. Print, Print Scan Copy (3in1) , fax is a bonus
3. Printing capacity per month is about 30 pages
4. Budget of $300 - $400
5. Wireless printing is a bonus
6. Duplex is a bonus as well
I used to use normal ink printers, and because i hardly use them they often ended up dried. So I have decided maybe I should try laser printers. I understand laser printer will not dry up if I don't use for months. Any recommendations is greatly appreciated. :)
ericktkj
Hi, looking for mono laser printer
(1) duplex printing (must)
(2)fax (must)
(3) scan (must)
(4) copy (must. but duplex copy will be bonus)
(5) wifi (not must, if have will be bonus)
(6) running cost must be cheap
(7) mainly for reports and contract
One mth 500 to 1000 pages.
Reliable machine.
Magickiller9
My canon printer ink carriage damn expensive thinking about switching as well. If let say print notes outside cost 5 cent each. Will it be cheaper if I buy the laswr printer and print at home?
Mainly for Uni. Must justify the cost ah to convince myself haha
Niaoson
My super old printer (OKI B411DN) recently started printing black specks everywhere. Position of the specks are random as though the printer is 'dropping' toner on the paper as it passes through. Any idea what might be the problem? Drum?
lin321
Hi I have a Xerox FujiCM205FW which print out very fade Colours despite my replacing with new cartridges (all 4 brand new)
Any idea why is this so?
Is there a drum that I need to replace?
kandinsky
3rd party toner or original? Sometimes 3rd party got this problem. I've one 3rd party toner, 'leaks' quite easily compared to the original even with normal handling.
See if got menu option to clean the 'fusing unit'.
gairyu
hi all need recommendation for laser printer
1. Duplex colour laser printer with print scan copy & fax)
2. wireless printing preferred though not a must
3. Able to print up to A3 if possible
4. No Budget yet sourcing for brands and prices around first
I do colour print occasionally about once a month but i'm have heavy usage for B&W so I'm concerned about the cost of toner also.
Thank you.
Magickiller9
I need a new printer my ink 1 sucks =((
1. Black and white will do
2. Laser
3. Cost effective
4. can scan.
M265z seems good.
MuppeJack
Looking for a new printer for home use, light user here.
Just 2 components I'm looking at,
1) scanning feature
2) cost effective
Any recommendations greatly appreciated!
GogoLover
Auto duplexing and borderless
Hi all,
Do anyone have any idea which printer support auto duplexing and borderless print at the same time?
