[Printer] Laser Printer questions lip lai !!!
tonerseller
Looking for a new printer for home use, light user here.
Just 2 components I'm looking at,
1) scanning feature
2) cost effective
Any recommendations greatly appreciated!
You need mono only or need color? Need wireless or usb connection will be fine?
tonerseller
hi all need recommendation for laser printer
1. Duplex colour laser printer with print scan copy & fax)
2. wireless printing preferred though not a must
3. Able to print up to A3 if possible
4. No Budget yet sourcing for brands and prices around first
I do colour print occasionally about once a month but i'm have heavy usage for B&W so I'm concerned about the cost of toner also.
Thank you.
If need A3 then will be copier ard 6-10k.
IF really heavy then should just get Fuji Xerox M455df (mono multifunction)
$2,499 and they charge you 1.6 cents per mono print.
Cause colour laser printer tends to have a high mono per page cost.
If really need colour then can consider
Samsung CLX-6260 or Canon MF8580cdw
bndreve
Hi, can all laser printers print on photo paper?
If I want to print 4R or 5R size photos, any recommendation?
Thanks.
wlun228
Hi, been using the cheap Brother HL 1110 mono laser printer for a year and it is great, not giving me any problem at all.
However looking for another laser printer.
Laser, Scan, Colour. any recommendation? prefer the cheapest 1 and fuss free.
ryuki101
Need recommendation for (pure) laser printer, with auto duplex function.
Can recommend a cost effective one?
Can recommend both B/W & colour ones, for comparison?
Thanks!
engsan13
Hi I have a Xerox FujiCM205FW which print out very fade Colours despite my replacing with new cartridges (all 4 brand new)
Any idea why is this so?
Is there a drum that I need to replace?
I'm having a similar problem with my FujiXerox CM215B. The BLACK colour colour is NOT coming out despite changing compatible black toner cartridge twice already. Other colours seem to be OK when I print the demo page.
Toner problem or more serious printer hardware problem, anybody can advise?
Success
Fuji Xerox DocuPrint M225 dw
Fuji Xerox DocuPrint M225 z
Fuji Xerox DocuPrint M265 z
Thank you very much.
I am looking for mono color, can scan and auto duplex.
Which of these 3 models do you recommend? Any good place to buy Fuji Xerox?
http://www.fujixeroxprinters.com.sg/en/Products/MultifunctionPrinters/DocuPrintM225dw.aspx
http://www.fujixeroxprinters.com.sg/en/Products/MultifunctionPrinters/DocuPrintM225z.aspx
http://www.fujixeroxprinters.com.sg/en/Products/MultifunctionPrinters/DocuPrintM265z.aspx
slowth84
Can I confirm the FX M265Z can do double side scanning?
Can it do that via the ADF or only fed manually page by page on the scan bed?
Can it do this wirelessly to MAC? Or only windows?
Thanks!
noangel7
no particular recommendation.
depends on your budget and requirements on specs
all 3 are mono, can scan and can print auto duplex
M265z can also auto duplex scan according to specs.
You can compare prices from Lazada (with discount code), Qoo10 (with coupons) as well as shops like Best Denki, Challenger, Harvey Norman etc
Thanks!
See if anyone who owns this printer can help you or ask the salespeople in stores.
ah_mah
Thanks!
Im a M265z user for almost half a year. Yes it can auto duplex print and auto duplex scan (via ADF). I connect my printer to my router (using ethernet cable) coz there was some issue with the static/auto ip address when i tried connecting the printer via wifi to my computer. The ip address got reset every time i switch off and on the printer. Now on wired ethernet connection, I dont hv any more of the ip address problem and it works everytime.
cloud0
Any recommendations for a laser printer:
- duplex
- black and white
- high volume (5k a month)
- wired or wireless
- no scanning required
- able to print on 200gsm paper
Magickiller9
So i brought this fuji m225 dw printer. It says the first cartridge is about 1.1k pages, but after printing 400+ it's out of ink liao o.o....
sgmem88
Having similar problem with my cm205fw....black color printout is very fade, rest of colors are ok. Problem seem to be the compatible black toner cartridge, as other colors cartridge are genuine...
Finally solved my problem following solution here....
http://www.techsupportforum.com/forums/f109/xerox-phaser-6250-cyan-printing-faintly-303404.html
By changing a new cartridge and printing blocks of rectangle in black only for almost 10 pages, I can see the black color slowly coming back :)
