[Printer] Laser Printer questions lip lai !!!
commach
This model no auto-duplex? I personally don't buy printer without auto-duplex, YMMV.
So far Fuji Xerox printer serve me well, no complain.
oakhub
I am looking for a colour laser printer.
a low usage user, typically a year may print less than 100 pages, mainly mono. I do not need a all-in-one.
main thing to me is, I want something less bulky, does not take up so much space.
I saw this on qoo10, is this good?
http://list.qoo10.sg/item/FUJI-XERO...RINT-CP225W-AIRPRINT-N-GOOGLE-CLOUD/429225022
This one duplex quite difficult. Need to open tray. I'm using Cp215w bought at $99 which has a top feed. Just take out n flip around. This now there is a similar model cp115. You can look at that too.
chengsun
thank you, i have checked out cp115w online. think i will wait for coming IT Show in March to check out the actual thing, and the price. my main concern is the size. if it is no smaller than my current epson MF, then it defeats the purpose of us changing it...
nakata97
Just need some advice
I'm thinking of getting a laser printer
Some info
Low usage (typically maybe 30pcs a year)
Don't really print Colour pictures but would like to have
Don't really copy or scan but would like to have this also
Budget around 300-400
Initially was thinking of getting the HP 177FW MFP but worried that it's a overkill as not a heavy user at all. Also, it don't have auto duplex which is a letdown
So my question is :
Would you get a laser monochrome MFP as most proper Colour laser MFP is expensive or
Would you get a laser Color printer only. Use handphone to take pictures of documents if needed?
edward.t
Need some advice, looking for mono chrome printer.
AUTO Duplex must have
Wireless Network (Stable)
Reliability
Good Warranty Coverage
Small Foot Print
Which model would you recommend?
free2d
What is good and cheap mono laser printer, non duplex, small size, wireless/wifi?
Using Brother HL1110 snd need smother one.
Thanks.
t258jgn
Which AIO Colour Laser Printer has the smallest foot print?
Currently using Xerox CM225fw.
Need to change to smaller (L x W)
VTEC3100
Need a color laser printer for home use.
Low usuage. Perhaps less than 20 page per month.
No need duplex, easy to clear papaer jam.
Wireless or usb cable connect also can.
Budget below $400.
Best come with full starter cartridge .
Thanks in advance.
mcforlife
Anybody knows if Canon printers in the US same with SG? Just that the model code is different isit?
Now i am looking at Canon MG5770 sold in SG, is it the same as MG5720 sold in the US?
Thanks! Any advice is appreciated!
scorpio76
Anyone has any used original ct201591 black toner for Fuji Xerox CP215B lying around? I am looking for one.
Shahmatt
Hi all. Looking for a simple bw printer. No need other functions but duplex would be useful. Maybe less 100 A4 pages per year. What's good and durable to buy?
testerjp
Is there any cheap laser printer that can be connected wirelessly to a macbook?
damnit
I have the same issue with my CP115W as well. Black prints very faint and was OK initially. Changed toner also no joy.
Seems like quite a number of folks reported same issue here with their FX color lasers. Feeling very disappointed with FX.
Going to try the print black box method when I get back home today and see if it solves the issue. Already contemplating to throw it away and get a Canon G2000 liao.
I think FX color lasers should not be recommended here at all in view of the reported issues with black fading after using for a while.
I had the same issue too during my last few months of warranty. Called FX and they came to my place the next day. The technician took a quick look at the issue and said this cannot be repaired and needs to be brought back to HQ.
I was shocked as I needed to use the printer. He said no worries as he already brough another new set to replace for me. He promptly went to his vehicle and took out a new one, and replaced it on the spot within 10mins.
This is my third FX printer and the service is awesome!!!
