Problem/s with Win8 - Post Here !
human_shieldz
Thanks, will tried later.........................:)
By the way, my modem is connected by the comm port and not USB port.....................;)
Wah comm port? Shouldn't it be at least the LAN port?
You are using desktop i presume? Why not try to use LAN? With that i don't think you'll have any issues??
coyote
you are using 56kbps analog.modem?
That will be classic!
Jeremy1
Sorry it's LAN. Thought comm and lan is the same.
I am using this cable modem, Motorola SBV5121.
human_shieldz
Ok but then don't you think it's strange that you installed win 8 and your cable modem not working? Not very link isn't it? Though anything is possible but if your cable modem receive power from your PC then it's not working i can understand but if it's through the wall socket and the only thing that connects to your PC is your LAN then the cable modem is likely the one having issue rather than Win 8. So far i heard installing Win 8 clean solve quite a few of the issues mentioned for people like us who upgraded it from Win 7
Jeremy1
No, it's working fine & I can surf the internet but just that the bottom right always once a while prompt u a notification saying that "USB is not abled to recognise this unknown device".
Now, I am connecting also the USB from the modem to the computer as well and see is it ok or not. Is it ok to connect the USB & Lan cable from the modem to the PC at the same time ?
Now looked like the device name is appearing on the device manager.
See how.............................:)
coyote
Wow.... you are .... :s22::s22::s22:
There is no need to connect the usb, just the LAN port will do.
The USB issue should be another device connected to your pc, not the modem.
human_shieldz
Yeah when he said the USB is not connected from modem i blur liao hahahaha. Even if it's connected i also blur that he can surf when it's not working hahahaha. Anyway, i think everything is ok now la, that USB is like what coyote said, it's another device.:s13:
Jeremy1
Look like it's OK now even not connecting the USB cable.
I just assigned my hardware id.
fabian79
anyone having issues syncing google calendar to the native calendar app in windows 8? i have no issue with mail and contact... but calendar dont show even after sync completed.
SimonLam
Moderator
Moderator
Anyone has problems using PowerDVD12Ultra on Windows 8 to play Blu Ray Movies?
Suspect its PowerDVD program as I can open the BD movie in VLC
havetobuy
power dvd 12 olredi had problemo since win7
i had been usin zoom player 8.16 skin browser not as nice as power dvd12
but it can play all formats
SimonLam
Moderator
Moderator
I got it working liao...
Its the famous Error 80004005: Unspecified Error.
After playing around, need to run it in administrator mode. It was not like that a few weeks back. Maybe a windows update changed that.
SimonLam
Moderator
Moderator
Now WinZip also need to be run in administrator mode to zip/unzip properly...
Strange...must be one windows update that had caused it.
Edit: Confirmed...something wrong with the system temp folder. point to other directory, everything ok.
fatendestiny
was using Win8 since Nov, and lately in Dec onwards, it keep freezing.
tried to repair the files in Win8 but the random freezes kept coming back.
