Proposal Ring - Part 3
Miltah
My waifu is size 6 leh.. even a 0.75 carat looks small on her.. really burned wallet :(
You could always upgrade in a few years.
If u brought from JP then its only the top up difference
Asian fingers are in general still slimmer than Caucasians
shin7829
Bought a infini love from hk zss
Certificate: IGI
Platinum ring
Shape and cut: round and brilliant
Carat weight:0.43
Color grade: F
Clarity grade : VS1
Cut grade : excellent
Comments : hearts & arrows
Inspected at shop .it has eight arrows
Bought at 3500 wonder is it a good deal or I myself being a bit liao lol
revilosb
http://www.chowsangsang.com/passionforbrilliance/en/
not sure about this store.
did they gave you a cert?
i got mine from Jannpaul
Octagon 0.513 F VVS1 - $4,850 (diamond only)
Certificate: IGI
Platinum ring
Carat weight:0.43
Color grade: F
Clarity grade : VS1
Miltah
Certificate: IGI
Platinum ring
Carat weight:0.43
Color grade: F
Clarity grade : VS1
I would go with AGS and GIA as the top 2 labs.
Color grading is often subjective and might be less accurate with other labs
Hearts and arrows only show symmetry with some light info but best to verify with ASET scope.
I dun presume u are after much after sales service since you bought in HK, so a comparative online diamond I.e.The following Whiteflash ACA 0.498C, F, VS1 is $2400 (delivered, gst added, excluding setting)
https://www.whiteflash.com/loose-diamonds/round-cut-loose-diamond-540865.htm
summersky1986
Thanks thanks, Saturday visiting JP again for resizing and wedding bands
Sent from 10char using GAGT
XxlwAteRzlxX
I will save the $500 and pick the 0.533 F VS2. I doubt you can see the difference between the VVS1 and VS2. Unless it really bothers you mentally.
P.S. Good choice with the Octagon. I bought an Octagon too!
Same here, 0.533. $500 very good to use.
What about comparing the 0.533 F with this new 0.557E ?
Price difference of $1000
Old - Octogan 0.533 F VS2
New - Octogan 0.557 E VVS2
sugaricing83
Would still choose the 0.533. As they have said earlier, you cant tell the difference between VVS2 and VS2 with naked eye.
KinoChoco
Certificate: IGI
Platinum ring
Carat weight:0.43
Color grade: F
Clarity grade : VS1
Infini love is just a standard normal commercial ideal cut, no ASET scopes are used to assess their light performance.
It's like getting a Astor Ideal from bluenile, which is about 2k-2.1k after GST for diamond alone.
Miltah
Would u see a size difference? Unlikely much
Would u see a color difference? Unlikely
Would u see a clarity difference? Unlikely with naked eye
Would I pay $1000 for benefits I can’t see? Only if the 0.557 numbers mean something meaningful to you and your gf
