Real International speed tests
What ISP are you testing on?
  • Total voters
    64
they assigned me a new IP.
So you have a static IPv4 address and they change it for you, then the issue got resolved.
That sounds very strange. It seems to me there were issues from Viewquest side and they just want to find an excuse.
For example if your existing IP address segment has bad routing but that should just affect the international sites speed and should not really affect the local speed to Viewquest speed test server.
Anyway, glad that you sorted out the issue.
firesong
Deluxe Member
Looks like 2 servers fell out.
ServerLatencyDownloadUploadLoss
Singtel - Singapore (id = 25960)1.91ms (Jitter = 0.05ms)937.6Mbps (data used: 6.7GB)943.17Mbps (data used: 9.1GB)0.00%
ViewQwest - Singapore (id = 2054)2.82ms (Jitter = 0.14ms)941.56Mbps (data used: 3.7GB)936.93Mbps (data used: 8.7GB)0.00%
PT FirstMedia - Singapore (id = 7556)1.97ms (Jitter = 0.09ms)937.59Mbps (data used: 6.8GB)934.55Mbps (data used: 8.4GB)N/A
Comcast - Sacramento, CA (id = 9436)176.66ms (Jitter = 0.06ms)896.48Mbps (data used: 11.1GB)116.79Mbps (data used: 1.3GB)0.00%
Spectrum - Los Angeles, CA (id = 16974)184.84ms (Jitter = 0.11ms)855.0Mbps (data used: 10.2GB)125.2Mbps (data used: 1.2GB)0.00%
University of Texas, Austin - Austin, TX (id = 16089)227.06ms (Jitter = 0.12ms)282.31Mbps (data used: 3.8GB)4.8Mbps (data used: 0.1GB)66.67%
Optus - Melbourne (id = 30932)106.85ms (Jitter = 0.07ms)920.42Mbps (data used: 12.5GB)184.47Mbps (data used: 2.6GB)0.00%
Misaka Network, Inc. - Tokyo (id = 44988)84.18ms (Jitter = 0.13ms)957.58Mbps (data used: 11.9GB)195.51Mbps (data used: 1.2GB)105.63%
Bell Mobility - Vancouver, BC (id = 17402)240.04ms (Jitter = 0.3ms)943.14Mbps (data used: 10.6GB)112.85Mbps (data used: 1.0GB)0.00%
Telstra International - Hong Kong (id = 44340)34.82ms (Jitter = 0.17ms)868.35Mbps (data used: 10.1GB)523.33Mbps (data used: 6.0GB)0.00%
bert64
You'd think that, but static addressing makes for very inefficient use of the address space. With dynamic addressing they can move address blocks around according to how many customers they have on each node etc, with static that becomes harder.
You want to route larger address blocks because you lose 3 addresses every time you create a subnet, and legacy ip addresses are expensive and in short supply.
You route a small block for static customers to a particular area, then most of those customers leave and go to another provider - now you have a smaller number with a bunch of unused addresses and you want to reallocate some of the addresses to customers elsewhere - only you cant, because you've committed to providing a static address to a customer in that area so you can't move the whole block easily.
So you end up with very messy hacks where you tunnel certain addresses back and forth etc.
That's why a lot of providers don't offer static addressing at all and many that used to don't anymore. That's also why AWS uses NAT for all IPv4 users etc.
With IPv6 this problem goes away, as you have no shortage of addresses and can just leave large blocks assigned incase you have customers to use them in the future. You also don't waste 3 addresses per subnet, not that it would matter anyway.
rubicon
just want to clarify something. I never had static IP. They just said they needed to change my IP and do something at the backend. The problem has been fixed since then. it's probably some routing / NAT / oversaturation of some node.
i'm getting decent speed on wireguard, around 80 to 90 Mbps constantly on Beryl, which is sufficient for my streaming needs.
firesong
Deluxe Member
Have left a cronjob to track speeds. Just pulling up today's.
PT FirstMedia - Singapore (id = 7556)1.9ms (Jitter = 0.15ms)940.97Mbps (data used: 3.7GB)927.55Mbps (data used: 9.3GB)0.00%
Comcast - Sacramento, CA (id = 9436)188.91ms (Jitter = 0.06ms)938.38Mbps (data used: 11.7GB)118.58Mbps (data used: 1.7GB)0.00%
Spectrum - Los Angeles, CA (id = 16974)174.72ms (Jitter = 0.17ms)909.31Mbps (data used: 11.5GB)135.45Mbps (data used: 1.9GB)0.00%
University of Texas, Austin - Austin, TX (id = 16089)236.65ms (Jitter = 0.11ms)209.37Mbps (data used: 2.8GB)55.72Mbps (data used: 0.7GB)0.00%
Optus - Melbourne (id = 30932)110.03ms (Jitter = 0.15ms)939.82Mbps (data used: 11.6GB)201.51Mbps (data used: 2.8GB)0.00%
Misaka Network, Inc. - Tokyo (id = 44988)80.89ms (Jitter = 0.11ms)746.03Mbps (data used: 5.8GB)164.16Mbps (data used: 2.3GB)0.00%
SIMPLYCONNECT - Dar es Salaam (id = 13902)448.83ms (Jitter = 0.15ms)2.69Mbps (data used: 0.0GB)19.25Mbps (data used: 0.3GB)0.00%
Celcom Axiata - Kuala Lumpur (id = 4956)223.25ms (Jitter = 0.17ms)387.97Mbps (data used: 3.8GB)120.41Mbps (data used: 1.5GB)0.00%
Bell Mobility - Vancouver, BC (id = 17402)243.57ms (Jitter = 0.12ms)928.18Mbps (data used: 10.5GB)135.33Mbps (data used: 1.3GB)0.00%
Telstra International - Hong Kong (id = 44340)32.66ms (Jitter = 0.1ms)939.51Mbps (data used: 9.6GB)595.08Mbps (data used: 8.3GB)0.00%
Edit: Was going through my archives and noticed the last time I had results from Singtel and Viewquest was on 10 Feb 2022. I hope that does not mean that I got blocked by their firewall - only one test a day. :(
Just did some checking. -s25960 throws up [error] Configuration - No servers defined (NoServersException). Viewquest works okay on the CLI, so I'm guessing it's a firewall block.
firesong
Deluxe Member
Took my NAS dying and needing to be redone to get down to this. There's a Docker container that does hourly speedtests and charts the results.
https://hub.docker.com/r/henrywhitaker3/speedtest-tracker/
For those doing it on their Synology NAS, you'll need to manually add the speedtest executable to the relevant BIN folder (eg, /volume1/docker/speedtest/www/app/Bin) and run a command to accept the EULA.
1. Get the latest executable from: https://install.speedtest.net/app/cli/ookla-speedtest-1.1.1-linux-x86_64.tgz
2. Extract it on your PC. Copy the speedtest executable to the BIN folder (eg. /volume1/docker/speedtest/www/app/Bin)
3. Execute php /config/www/artisan speedtest:eula to accept the GPDR.
3a. For Synology NASes, you can either SSH in or just run it off the Docker-> Console or Portainer -> Console.
Haven't gotten it to work on my Ubuntu ARM box - it doesn't state that it supports ARM, so I'm guessing there might be an issue with the architecture.
Simple enough interface. Am letting it populate.
Edit: Did some digging. Had to use the dev-arm flag for the ARM64 architecture - so for those with a raspberry pi lying around, this is a useful docker container to have. A simple speedtest every hour, and tracked - gives a good overview of how your network performs at a glance.
XML:
version: '3.3'
services:
    speedtest:
        container_name: speedtest
        image: henrywhitaker3/speedtest-tracker:dev-arm
        ports:
            - 82:80
        volumes:
            - ./data:/config
        environment:
            - TZ=Asia/Singapore
            - PGID=1000
            - PUID=1000
            - OOKLA_EULA_GDPR=true
        logging:
            driver: "json-file"
            options:
                max-file: "10"
                max-size: "200k"
        restart: unless-stopped
Singtel Speedtest server id has been changed to 13623. Viewquest speedtest server id is still 2054.
Code:
PS C:\work\speedtest\ookla-speedtest-1.1.1-win64> .\speedtest.exe -L
Closest servers:
    ID  Name                           Location             Country
 31293  Pacific Internet (S)           Singapore            Singapore
 28640  Webe Digital Sdn Bhd           Iskandar Puteri      Malaysia
 44962  Sunway Iskandar                Nusajaya             Malaysia
  7311  M1 Limited                     Singapore            Singapore
 13623  Singtel                        Singapore            Singapore
 31180  Campana                        Singapore            Singapore
  5935  MyRepublic Singapore           Singapore            Singapore
  7556  PT FirstMedia                  Singapore            Singapore
  4235  StarHub Mobile Pte Ltd         Singapore            Singapore
 37744  Telekomunikasi Indonesia International Pte Ltd (Telin Singapore) Singapore            Singapore
Ref:
https://linuxspeedtest.com/server/id-13623/singtel/https://linuxspeedtest.com/server/id-2054/viewqwest-pte-ltd/
fishburger123
I am using a Raspberry Pi 400 running OpenWRT as my router now. Its CPU is pretty fast. I am using the Ugreen USB to Gigabit Ethernet adapter as the WAN port and the built-in Gigabit Ethernet as the LAN port. Then I connect my free Singtel Mesh Router to the LAN port as the wireless AP. I have another Raspberry Pi 400 for running different distributions of Linux. Both can sustain near 1Gbps wired connection using SpeedTest-CLI or iperf3.
My Asus RT-AX82U has a weaker CPU which is not good enough for near 1Gbps wired connection using SpeedTest-CLI or iperf3. So I have another Intel J4105 mini PC connected to both my RT-AX82U and my Raspberry Pi 400. With that Intel J4105 mini PC, I can run easily different utilities like SpeedTest-CLI, iperf3, librespeed-go, etc. I am also experimenting with Docker on the Intel J4105 mini PC which has 4 LAN ports. Previously I was running pfSense using the Intel J4105 mini PC but I feel it is a bit wasted just running pfSense.
I'm curious, how is your home network wired up? Do you have two ISPs or you only have the Raspberry Pi 400 to do the routing but the ASUS AX82U in AP mode?
Both of them are running in router mode with respective public IPv4 address. It is a special feature for Singtel ONT users where you can get two seperate networks, if you use a VLAN switch.
Ref: https://forums.hardwarezone.com.sg/...properly-singtel-asus-rt-ax86u.6564040/page-2
If you are not a Singtel ONT user, then you need to subscribe to dual 1Gbps plan (Singtel 1+1, Starhub 2Gbps, M1 2Gbps and MyRepublic 1+1) or dual ISP plans.
BTW, I have since switched the Raspberry Pi 400 OpenWRT installation to virtual pfSense VM running on Intel J4105 mini PC with PVE 7.0 virtualization plafform.
BTW, if you run OOkla speedtest client using embedded system (eg: your router, or ARM SBC), then you need to check whether itself is the bottleneck or not.
For example, my Asus RT-AX82U can run the client but the download speed is on the lower side.
Code:
/tmp/mnt/AsusUSB3/root# ./speedtest
   Speedtest by Ookla
     Server: Singtel - Singapore (id = 13623)
        ISP: Singtel Fiber
    Latency:     1.19 ms   (0.18 ms jitter)
   Download:   807.30 Mbps (data used: 1.4 GB )
     Upload:   937.78 Mbps (data used: 1.2 GB )
Packet Loss:     0.0%
 Result URL: https://www.speedtest.net/result/c/9519aee6-815c-47a3-8cad-260999f00df7
On the other hand, a low power Intel J4105 mini PC running PVE 7.0 has no issues.
Code:
root@pve:~# ./speedtest
   Speedtest by Ookla
        ISP: Singtel Fiber
    Latency:     1.40 ms   (0.09 ms jitter)
   Download:   946.01 Mbps (data used: 425.8 MB )
     Upload:   946.71 Mbps (data used: 1.1 GB )
Packet Loss:     0.0%
 Result URL: https://www.speedtest.net/result/c/89c9a669-9f2f-4904-acd6-5c7fc916a672
Even a Debian LXC container inside the PVE can run at full speed.
Code:
root@debianct1:~# speedtest
   Speedtest by Ookla
        ISP: Singtel Fiber
    Latency:     1.15 ms   (0.13 ms jitter)
   Download:   945.51 Mbps (data used: 460.6 MB )
     Upload:   946.81 Mbps (data used: 1.1 GB )
Packet Loss:     0.0%
 Result URL: https://www.speedtest.net/result/c/68ac9864-77b4-4e14-a9eb-9726b5e2a415
fishburger123
So that means you're able to have two public IPs? I'm using SingTel ONT as well,
firesong
Deluxe Member
Today's results.
Singtel - Singapore (id = 13623)1.59ms (Jitter = 0.08ms)948.39Mbps (data used: 3.4GB)946.07Mbps (data used: 9.1GB)0.00%
ViewQwest - Singapore (id = 2054)2.49ms (Jitter = 0.28ms)942.66Mbps (data used: 3.7GB)933.23Mbps (data used: 8.9GB)0.00%
PT FirstMedia - Singapore (id = 7556)1.52ms (Jitter = 0.22ms)929.79Mbps (data used: 6.6GB)935.2Mbps (data used: 8.9GB)0.00%
Comcast - Sacramento, CA (id = 9436)178.02ms (Jitter = 0.11ms)936.48Mbps (data used: 11.5GB)111.42Mbps (data used: 1.6GB)0.00%
Spectrum - Los Angeles, CA (id = 16974)174.69ms (Jitter = 0.11ms)939.7Mbps (data used: 11.8GB)144.29Mbps (data used: 1.3GB)0.00%
University of Texas, Austin - Austin, TX (id = 16089)223.75ms (Jitter = 0.22ms)263.44Mbps (data used: 2.5GB)16.07Mbps (data used: 0.3GB)0.00%
Optus - Melbourne (id = 30932)109.47ms (Jitter = 0.08ms)941.73Mbps (data used: 11.0GB)176.24Mbps (data used: 2.5GB)0.00%
Misaka Network, Inc. - Tokyo (id = 44988)88.93ms (Jitter = 0.74ms)710.52Mbps (data used: 5.7GB)148.87Mbps (data used: 2.2GB)117.65%
SIMPLYCONNECT - Dar es Salaam (id = 13902)459.97ms (Jitter = 0.19ms)3.55Mbps (data used: 0.0GB)6.43Mbps (data used: 0.1GB)0.00%
Celcom Axiata - Kuala Lumpur (id = 4956)214.45ms (Jitter = 0.09ms)452.95Mbps (data used: 4.3GB)107.86Mbps (data used: 1.5GB)0.00%
Bell Mobility - Vancouver, BC (id = 17402)249.2ms (Jitter = 0.06ms)808.62Mbps (data used: 9.7GB)101.27Mbps (data used: 1.4GB)0.00%
Telstra International - Hong Kong (id = 44340)40.2ms (Jitter = 0.03ms)942.4Mbps (data used: 9.6GB)934.04Mbps (data used: 10.2GB)0.00%
ChinaTelecom 5G - Guangzhou (id = 27594)192.41ms (Jitter = 1.2ms)114.58Mbps (data used: 1.2GB)1.4Mbps (data used: 0.0GB)555.56%
China Telecom - Shanghai (id = 3633)189.45ms (Jitter = 2.78ms)315.33Mbps (data used: 4.0GB)1.81Mbps (data used: 0.0GB)N/A
ChinaUnicom YunNan - KunMing (id = 39012)95.71ms (Jitter = 0.29ms)348.55Mbps (data used: 3.2GB)241.69Mbps (data used: 2.1GB)N/A
Singtel's international upload speeds seem to have dropped to 10-15% of the gigabit bandwidth, especially noticeable with servers that have gigabit download speeds.
Edit: Added 3 China servers. Upload speeds to Guangzhou and Shanghai are imo unusable at 0.3% of the download speeds.
firesong
Deluxe Member
Updated the scripts in the first post. Added Chinese servers.
# ChinaTelecom 5G - Guangzhou, CN
27594
# ChinaTelecom - Shanghai, CN
3633
# ChinaUnicom - YunNam, CN
39012
lobukong
server namelatencypacket lossdownloadupload
Singtel - Singapore2.30707823020359095273
ViewQwest - Singapore2.3609423903859455518
PT FirstMedia - Singapore2.70408162505859468351
Comcast - Sacramento, CA169.704014734731485025
Spectrum - Los Angeles, CA167.497015546391578176
University of Texas, Austin - Austin, TX204.914012455071320296
Optus - Melbourne216.4011761721186917
Misaka Network, Inc. - Tokyo84.049029191182768793
SIMPLYCONNECT - Dar es Salaam276.790949721944697
Celcom Axiata - Kuala Lumpur10.31502126798923041270
Bell Mobility - Vancouver, BC193.863013788691366381
Telstra International - Hong Kong32.127072943235511478
ChinaTelecom 5G - Guangzhou234.1710.416667671277296194
China Telecom - Shanghai429.5N/A214935124409
ChinaUnicom YunNan - KunMing150.788N/A16983521691005
results for myrepublic. looks OK except the China servers.
firesong
Deluxe Member
Looks good. I attached an Excel spreadsheet in the first post that automatically formats the raw CSV results so it's more human readable.
To use it,
1. Open the excel spreadsheet.
2. Go to Data toolbar
3. click "Refresh all".
4. Select the results-yyyymmdd.csv and the bottom table on the "Results" tab will be generated from the imported entries.
5. Change tab to the "Alternate" and copy/paste from there.
Choose_a_File_and_Speedtest_Results_Converter_and_Real_International_speed_tests___Page_4___Ha...png
Hope this helps. :)
For Singtel, I think China Mobile servers seems to offer better speed.
Code:
root@debianct1:~# speedtest -s 4647
   Speedtest by Ookla
     Server: China Mobile Group Zhejiang Co.,Ltd - Hangzhou (id = 4647)
        ISP: Singtel Fiber
    Latency:    92.30 ms   (4.68 ms jitter)
   Download:   971.95 Mbps (data used: 1.6 GB )
     Upload:   657.80 Mbps (data used: 1.1 GB )
Packet Loss:     0.0%
 Result URL: https://www.speedtest.net/result/c/ddb5e7cd-f794-435b-b227-71797f9f8915
China Telecom sites are usually not as good.
Code:
root@debianct1:~# speedtest -s 5396
   Speedtest by Ookla
     Server: China Telecom JiangSu 5G - Suzhou (id = 5396)
        ISP: Singtel Fiber
    Latency:   324.60 ms   (0.08 ms jitter)
   Download:   210.05 Mbps (data used: 258.3 MB )
     Upload:   190.48 Mbps (data used: 315.2 MB )
Packet Loss: Not available.
 Result URL: https://www.speedtest.net/result/c/c23090c9-88ee-47b6-b7b0-43eada8fdfef
firesong
Deluxe Member
Code:
   Speedtest by Ookla
        ISP: Singtel Fiber
Packet Loss:     0.0%
Code:
   Speedtest by Ookla
        ISP: Singtel Fiber
That's a fair point. I chose the servers for location, not for ISP. That was the physical factor, since we cannot know the actual speeds to particular locations if they don't provide multiple test servers for us to test different ISPs.
Then there's the more important factor - we don't know what ISP the other party is on, and whether they have throttled speeds on their end too. We are testing servers opened to the world, but it may not represent customer experience, since access within China is greatly firewalled from the world.
If customers are on China Mobile themselves, they might enjoy better speeds. But what if they are on China Telecom?
