Recommend an AIO cooler!
ItsmeagainhK
Get Artic or corsair or nzxt wont go wrong one. If still not satisfied, delid your cpu.
watzup_ken
Bump. ID cooling coolers good ? Like the auraflow 240
Never used their AIO before, but based on my experience with their air cooler, I feel the quality is just borderline pass. So I won’t recommend buying their AIO. Perhaps you should wait to see other’s experience or opinion as well.
watzup_ken
5600x hot chip lai de :/ use 360mm~
This is overkill man. The peak power for the 5600X is about 100W, which can easily be handled by a 240mm AIO. If the casing permits, a 280mm radiator is better due to bigger fan/ lesser noise, and it cools better than a 240mm AIO.
watzup_ken
Quieter. My evga is a jet engine
Posted from PCWX using LYA-L29
360 is not much quieter assuming you are using the same fans. On the contrary, it may be noisier due to the use of 3x 120mm fan vs 2 on the 240mm AIO. A 360mm radiator just means more surface area for cooling, which translates to better cooling capability. The fan may not have to run that fast on the 360, but by virtue of an extra fan will increase the decibels by a few points.
gonnie
Is quieter, at least mine 360 vs 240 haha the 360 is quieter. Not too sure for 280, case doesnt allow :(
I got
NZXT 360 (I9-9900K) idle 34-38
NZXT 240 (I7-8700K) idle 35-39
CM 360 (TR4 2950x) idle 35-39
AURA FLOW 240 (I7-2700K) Idle 42-45
Basically, if only normal use all are okay.
watzup_ken
Is it the same brand? Generally, its the fan used that is the culprit for the noise. So if you are comparing 2 different brands, then good chance the fan used will be different, which explains the noise reduction.
It is possible for a 360 AIO to be quieter, if the CPU is not running hot. If the fans on both 240 and 360 are running at high RPM, then the 360 will be louder due to the extra fan.
gonnie
Yea NZXT 360 and 240.
yea I supposed you are right, seldom to have the cpu load for too long, normally just spikes.
hg2
I got
Same here i9 Kraken x53, 33-36c happy CPU... previous AIO only lasted 6mnths and suspect the pump dead, as CPU temp reach 110c unable to come down... no more cheap AIO for me... all kraken now..
gonnie
Same, now waiting for Z73 to come in stock..my upcoming pc stuff all arrive except Z73 no stock..zzz
Prolly arctic liquid freezer 2 is good too.
jasonwsc
Dun anyhow BS la. 5600x stock cooler is wraith stealth, you need 360mm AIO for fk.
Honestly a normal tower cooler like the hyper 212 is fine for a 5600x, even a 240-280mm is kind of overkill.
FroztSpectre
I just recently bought ID Cooling Zoomflow 240X from Taobao for my fiancee's comp. Bought it at RMB329.00 (roughly $65.80) before shipping.
Then i swap the fans with ID-COOLING DF-12025 ARGB.
Supposedly 56.5CFM and 1.99mmH2O. 900~2000±10%RPM
So far so good ba. Using Ryzen 5 3600. Stock cooler under load was getting close to 80degrees c. Now under load is like 68degrees c max.
Default fans for the ZoomFlow 240X is supposedly
62CFM, 1.78mmH2O, 700~1500±10%RPM.
KleoZy
Hi,
Am thinking of picking up an AIO cooler as an upgrade. For those who are using an AIO already, which brand would you recommend and how was the ease of install? What temps are you currently getting in our humid weather?
Thanks
I for one will never like to go argb, creating some heat while running. For most easiest mounting would be the Arctic Liquid freezer II 280 or 360. if you really need argb, go for EKWB EK-AIO 360 both not using the Asetek mechanism.
Navillera
Using the ID cooling zoomflow 240X snow for my 5800X currently and it is serving me well. Also used auraflow 240 snow and zoomflow 360 black before, served me well too. No complaints with their aio. Cheap and decent
Posted from PCWX using iPhone13,2
leeerwin
Thanks for your feedback !
