Recommendations for fridges
KayElf
I recently just purchase the Sharp VX57PG.... think one of the best i came across when i went fridge hunting in several places. Can consider
How much you bought? Why one of the best? What's the diff with Sharp VX57ES?
cloudangel
I paid $2280 for it a HM millenia walk. Basically my considerations were cost, space utilization and functionality.
I decided to go for a Japan brand because i felt they were better made? but those made in Japan were out of my budget (usually costing 4-5k).
Alot of fridges i came across when i was fridge hunting, although the litre might be large but they weren't effective in their space utilization (e.g. size of their compartments, depth..etc) because of their designs (e.g. the thickness of the doors..etc).
And i found the quick freezing, plasmacluster and moisture sealing compartments to be extremely useful
What's the diff with Sharp VX57ES? the difference is the color and VX57PG exterior is tapered glass (not so prone to dents, scratches and decoloration)
lkh007
My Mitsubishi 2 door fridge, bought since 2010 when i moved in my house, working perfectly till now..
No complain so far!
stanlawj
No complain so far!
Hmmmmm... have you checked your door seals for cold air leakage? Especially the freezer door seals? When the freezer door is closed, is cold air leaking out from any particular spot?
limpingsim98
Mitsubishi, anytime.
Yap, always check the compressor uses for the fridge. Not many brand actually use their own manufacture compressor. This is especially for the low and mid range fridge.
In fact many makers use the same compressor and similar design. Just the door and internal design plus logo change.
qhong61
How to check?
lkh007
We are looking for this model as well for our new bto. Definitely 1 of the best 4 door fridge with this pricing..
IcYFl4mEz
did u compared with Hitachi wb640?
trenzterra
Is chiller compartment essential for a fridge? I noticed a lot of the side by side dont have a chiller compartment
