Redmi Note 10 series
a4973
Hi all may I know if there is a setting on the RN10P to point download of only PDF content to the micro SD? Thanks
i1magic
When will they fixed the "wake up phone for Google Assistant" function again.
It was working so well on Redmi Note 8 Pro.
regionmaster
Anyone note 10 Left Right speaker unbalanced ?
Can equalize it in accessibility, but it only seem to decrease volume the other side so it's some extreme band-aid temp fix
Also when you using earpiece, hosei again need turn back
Rooney3
Does the pro come with esim? How to setup after getting the QR code from M1? Scanning it doesn't route to a website or anything.
eip1234
Anybody using 3rd party launcher? I'm using Nova7 ...
Today I updated the OS to 12.5.8 ... Full screen gestures don't work with FNG at all ... at the moment you select full screen gestures, you'll be warned that the System Launcher will then be used instead of any 3rd party launcher ... If you don't use the full screen gestures, yes you can still use FNG but there are 3 buttons at the bottom which are ugly and defeat the purpose of gestures ...
The previous version 12.5.4 were OK - full screen gestures + FNG were working ...
alex22
12.5.8 on which local operator?
eip1234
Starhub ... Why does it matter?
It is Xiaomi who pushes the OS to phones, in batches. If you haven't got yours, you'll receive it soon ...
gnixer
Whats the benefits of using esim?
I always wonder abt this
I find it no benefit especially for those frequent change mobile. Imagine each time the telco charge you for the esim profile.
btw my Malaysia limited purple starlight note 10S arrives. So hard to find case in taobao.
eip1234
I have used the ADB command then authorized FNG to hide the navigation buttons at the bottom of screen but still can't hide them ... xian ...
Seems like nobody here bother about his issue? 😑😑😑
ZhuTou!
U mean the home, back button etc?
Miui itself can remove the button
Inside setting
