Redmi Note 10 series
i1magic
erm this 1 like not bad....
ermm.............
I find that those phone cover with the extra corner protection really helps when we dropped our phone.
Md1
Received from courts yesterday. Mixed feeling... Freezed Black screen a few times with banking apps.. Will observe for few more days....
Seems to come with a preapplied screen protector, do I remove it first to apply screen gel?
BTW 3fingers screenshot works.
bryant_16
What happen? Banking apps not yet compatible with note 10 pro?
wongminmin
try updating to the latest firmware or do a reboot
yes
ZhuTou!
Update latest miui FW and do factory reset
Md1
Idk what happened, just a black screen with dBs, paylah, tracetog, singpass .... Maybe its mi mover problems when migrating from note 9... Cc apps citi, sc, HSBC OK...
Spend 5hrs yesterday nite reset and reinstall all apps....will ki-xiao if paylah still cannot work...
wongminmin
black screen is due to
1. incompatible app
2. data corruption
hg2
For security reasons, banking apps have build in measures to prevent you transferring apk from phone to phone. Some less secured one will force a re-authentication if the apps detect a hardware/biometric-data change.
So, my best advise is to do a fresh install (it only takes a few seconds of ur life) from playstore again to ensure it's fully working again.
ZhuTou!
So far i use mi mover few times no problem but ya likely corrupted apps lor
Usually factory reset will solve most xiaomi problem
Sometimes new phone will have FW issue de, for xiaomi only :s13:
bbcccc
all other methods for screen shot wrks.
only the damn 3 fingers dun.
both poco x3 pro n rmn10pro
both on latest fw n local global rom sets...
angry...
Sent from LG Wing
matrix05
Try a fresh install from playstore. Bank app cannot work is a deal breaker .
rover75
Before setup new phone, backup everything from your old phone to google drive. When power on new phone, will see an option to setup from your backup on google drive. I did that on my Poco X3 Pro and everything was good including banking apps. The only downside was to rearrange your apps and sign-in to setup all the shopping apps cos I did not want to save all my passwords on Goggle.
