Redmi Note 10 series
i1magic
i save internal storage better somemore stable also. microSD card unstable & corrupted data lost
Yah. I know.
But what if you drop your phone and the screen cracked or due to whatever issue, phone cannot power up.
Then how do you retrieve the data that is in your phone's internal storage?
Asus80
Yah. I know.
u try plug usb cable in computer retrieve the data. last time my samsung note 9 screen cracked lucky plug usb cable in computer retrieve my data back
i1magic
I kena before and I tried. For MIUI, you will need to select what to do after plugging in the USB cable, so stuck.
kottty
only for the 1ST time..or u can change what connection at developer mode there
Read HWZ Forum Rules!
i1magic
Wah, this is good.
But does this means also that if we lose our phone, somebody can also just plug in a USB and access the data in the internal storage?
Also, what if the phone run out of battery and turned off? After we charge it up, we will have to to key in PIN or pattern to unlock the phone first before we can access the data in the internal storage?
I just tried, I need to unlock the phone first before it will show up the storage in Windows.
kottty
Wah, this is good.
of course u have to unlock the phone first..but like u said if screen crack can't unlock and still u can unlock using fingerprint..unless both can't den bo bian..
i1magic
If phone runs out of battery. After your charge it up and turned on, you will have to use the screen to unlock with PIN / pattern before you can have access.
So if the screen is gone, then data will be stuck inside.
I kena-ed this, LPPL have to replace the screen.
ZhuTou!
Yah. I know.
Google will auto save all photos
Just use pc login ur email u can see every photo
I think login is under google drive?
Or maybe google photo, forget liao
stillgottheblues
Google photos but there is a setting in Drive to show your photos too.
i1magic
Yes. But I disabled it already. Because Google Photo will no longer be unlimited starting from 1 Jun 2021 and whatever we sync will be counted towards our storage on Gmail.
i1magic
Wah, Samsung Galaxy Note 20 Ultra 5G 256GB with warranty till 21 Jul 2021 going for $995.
Frankly, with Redmi Note 10 Pro 8/128 at about $400, this seems quite a good deal also.
kottty
was thinking maybe can use OTG mouse swipe and keyboard to enter pin..maybe it work..later i go try..haha
xtractor
Nice. Saw this case also. Is the edge soft silicone or hard type?
How much did you get your Redmi Note 10 Pro? 6GB or 8GB ram?
it is a hard case.the phone drop before lol when i put on top of my car sliding through the bonnet.no scratch or crack.
phone bought at Courts promo time
was going to sell my friend but he change his mind last minute
so i decided to used it
almost bought 1 more luckily he say he don't want to buy or else i got 2
i1magic
Now already May, cheapest is Grey one 8/128 for $388.
I can't find other cheaper lobang liao.
