Redmi Note 10 series
pigpigoink
Hows the phone
Lag anot?
Urs 4gb or 6gb?
4gb. ok for moi, simple usage only, no lag. Moi no high demand type, can use can liao.
Game wise ish faster and better than moi redmi note 4x...(obviously lol).
xtractor
lai liao 6gb/128gb version (Glacier Blue)
50 in stock $369
https://shopee.sg/Xiaomi-Redmi-Note...cal-Official-Warranty--i.178877065.3009700854
matrix05
biggest coupon I see so far is $25 , otherwise the common weekend coupon is $20
add $5 in qoopoint , means $170 .... remainder can buy 2x $100 virtual giftcard for 2% savings or grabpay rebate mentioned in hardware clinic i not sure
GoldFxx seller $200, then less off with coupon and giftcard/grabpay, to get close to 160. Ok, Thanks.
ZhuTou!
How is the compare with courts mi 11 lite 8/128 $349?
Anw, the next big deal day shd be 6.6 or 18.6 (?), as big as 11.11.
The only thing good abt mi 11 lite is slim and light
The rest lose to n10pro
FluffyCreamy
I noticed that my n10p seems to drain battery quite fast? Can't last for more than 1 day even though I don't use it to play games... Only surf social media and reply to messages... Is there some settings I need to change? My AOD is off.
Just Me
What's your average on screen time? 120hz refresh rate enabled/disabled?
Just Me
Currently around 4h50m... At 12% battery left~ Just realized my 120hz was enabled. Has disabled it now. Will see if it improves after next charge.
Ok. That on screen time is pretty bad. If the majority of the usage is on WiFi you should at least be getting 7hrs+
xtractor
can check the activity which is still running
just go to setting then battery & performance
can just manually "restrict background activity"
FluffyCreamy
It overnight drained from 92% to 74% this morning.. I closed all apps before I slept so I'm confused what's draining the batt. Has just manually restricted background activity of those non essential apps this morning. Hope the battery life improves today.
Edit: the battery page says "other" consumed over 30% (370+ mAh). But I can't see what is in "Other".
