Redmi Note 8
weeza77
Redmi Note 8 4/64GB Global Export set (1 mth seller warranty) @ $209*
Redmi Note 8T 4/64GB Global Export set (1 mth seller warranty) @ $218*
Redmi Note 8 4/64GB Local set (1 yr Xiaomi SG warranty) @ $224*
*Prices from Shopee after $20 discount voucher. :D
Any link for the Shopee Local set?
AcquiT
Do i need open google pay or on nfc will do for mrt?
Haha paiseh firts time use nfc hp lol
KalTorak
How to get the $31 off $280 voucher?
Its somewhere within the Shopee app, under 11.11 early bird vouchers.
Don't quite remember exactly, maybe need to play their 11.11 games then can access or try at 12PM.
KalTorak
Please share how to get further discount?:o
1) Play all the 11.11 games on Q10/Lazada/Shopee.
2) Grab as many coupons/vouchers/tokens/coins and stock up.
3) Utilize the discounts/coins when purchasing on 11.11 12AM onwards.
4) Look out for flash deals on 11.11.
Plastick
saw win digital selling note 8 4/64 china set for 180+.
for china set i can sideload google play store too right? other than that what other restrictions compared to global set(rom)?
NightRaven49
just need to unlock your phone and tap. of course nfc must be on and gpay must be set up with bank card first. usually nfc won't drain battery so much, so I myself just leave it on.
Audiology93
No 1080p on Netflix due to the lack of widevine L1 support.
Sent from LG G7 ThinQ using GAGT
KalTorak
China Redmi Note 8 M1908C3JE lacks LTE Band 7 (2600), which is used by the 3 major telcos.
Whereas Global Redmi Note 8 M1908C3JG (both export and local sets) have all the LTE bands (B3/B7/B8/B40) used here in SG.
Xiaomi Redmi Note 8 China (M1908C3JE)
https://www.frequencycheck.com/compatibility/x0bltEd/xiaomi-redmi-note-8-premium-edition-dual-sim-td-lte-cn-64gb-m1908c3je/singapore
Xiaomi Redmi Note 8 Global (M1908C3JG)
https://www.frequencycheck.com/compatibility/jw8XTkD/xiaomi-redmi-note-8-global-dual-sim-td-lte-64gb-m1908c3jg/singapore
Anyway, Redmi Note 8 4/64GB @ $175 (Finer) white color only if you intend to get CN set.
KalTorak
Redmi Note 8 Pro 6/128GB @ $308* (Local set with 1yr warranty).
*After $30 discount on Shopee.
Plastick
wah gg how important is that? does that mean no 4G capability? thanks a lot
NightRaven49
not really that important unless your telco is m1, the other telcos have 2 other lte bands that china set rn8 can use while m1 only has 1. anyway, 4g coverage in sg is generally pretty good, and 3g is still adequate.
Plastick
learnt something. thanks.:D
trifrost
Is there any heating issue when using note 8 pro to play games. I keep seeing conflicting reviews regarding this issue. Some reviews clock it at 40 degrees, some say max 45 degree and some showing hitting 50 degree.
Reviewers can reside in different place so the ambient temperature may be different. Even in Singapore you may get different results when the air-con is on or off. Usually you can take the high end of the values which is 50 degree C for outdoor use in Singapore.
All in all it will get hot when playing games -- price to pay for using MTK processor.
I read some testing results from Chinese website playing 王者荣耀 which is not that demanding yet the phone reaches 47 degree C in an air con room at about 25 degree C ambient temperature. Then the phone hits 67 degree C during Antutu benchmark testing.
NightRaven49
until u realise the 730 which is qualcomm's best midrange offering has similar thermal properties for less gpu performance.
From what I read that SD730G thermal is better than the MTK P90T. And real world performance is also comparable or better even though the benchmark may be lower.
Maybe Kirin 810 is even better?
Anyway, probably I am too biased against MTK but I just do not buy any phones with MTK CPU, too many negative comments in the past.
addats
Is the "XiaoMi Offical store Global" in shopee the offical local distributor store? Meaning if got issue can go to XiaoMi service center?
