Redmi Note 8
hk7310
Currently using Redmi note 4x.
Any bro can advice which xiaomi phone to recommend: Redmi note 7, 7 pro or note 8 and note 8 pro.
budget around $200. Reliable is my prime consideration. No gaming, only for facebook, WhatsApp eg..
davidwong
If you want nfc abit difficult with that budget if you don’t want nfc but a basic phone note 8 and note 9s will be recommended as seems SD will have longer and more freq support as reliability is you prime consideration.
If you want full function phone ie nfc and all the works, I think note 8 pro will be closest to your Budget.
Other bro can comment ?
Shutterbox
8 pro is hybrid sim right?
hk7310
I just want a basic phone, so as you suggest may consider note 8 or note 9s. many thanks! Any other recommendation?
ZhuTou!
i think note 8 only cost 100+ in shopee if u can wait.
Shipping takes awhile
PeasantBeing
Note 8 is at a good price already since it was launched last year. Note 9s still new so the price not much discount. I have the Note 8 and very happy with it for normal use.
Sent from HUAWEI EVA-L19 using GAGT
carboy00
For basic use, I feel Note 8 is more than adequate I feel, plus it being out for a while now, prices have dropped and software have been better optimised. I got a Note 8 for family member, replacing an aging Note 3. But of course if your budget can stretch, by all means Note 9S is good too, depends on your priorities. :)
Posted from PCWX using Mi A2 Lake Blue
hk7310
Advice noted, many thanks
prostcode
Hi guys.
Am looking at a phone with nfc. Right now is the Note 8 Pro the best bang for the buck? Or should I consider the Note 9 series?
What's the cheapest and latest promotion now for the Note 8 Pro? Anyone can share?
Thanks!
ZhuTou!
Hi guys.
Thanks!
9s dun have nfc
