Robot Vacuum Cleaner
shadow84
ICYMI, those on the Hydra S7 / Viomi, and using it mainly on tiles and hard floors, get this!!
2Pcs Drum Robot Sweeper Accessories for Conga 3490 4090 5090 Vacuum Cleaner Accessories
They are excellent!!
I bought these from TB and i dun see much difference over using on tiles. These are supposed to help collect dust better?
hawthawthawt
The Hydra S7 really cheap and good.. nothing comes close to it's price vs features right now..
my Hydra is in service for over 20 months already with 1 x $70 repair..
This one no joke now!
Get your $50 voucher here: https://qoo.tn/BtASfX/Q101761040
Then get the Hydra S7 with 1 year warranty here for $250 after voucher!! https://qoo.tn/BJBSfX/Q101761040
All for $250.. this is damn cheap for a LIDAR robot with cloth dragging function lor!!
Or if you are feeling richer, Roidmi Eve Plus for $450: https://qoo.tn/BfBSfX/Q101761040
$200 more for better build, twin side brushes and self-empty bin!
Hello, which is better in terms of battery and functionality? Compared to the ECOVACS DEEBOT OZMO T8?
Thanks! :)
ping2
Hi! Can check with you if you have any idea the qoo10 link provided for the roidmi comes with singapore 3 pin plug with safety mark?
MGeaR356
Can check any recommendations for latest xiaomi mop + vacuum robo? Like which model
Tornesoul
Any comparison of the robot vacuums with autoempty function?
Roborock vs Dreame vs Ecovacs?
touchring1
anyone using samsung jetbot? I've been using it for 2 months, daily, so far ok, no breakdown and doesn't get stuck, except on loose cables which I need to make sure don't lie around. hopefully, it can last.
galant22
i'm using the roidmi eve plus, the one with the mop function.
one thing i realised after each mop/vaccum routine is that some water do get sucked into the auto empty station, causing the pipe leading to the emptying bag very smelly over time.
wonder if there is any empty stations out there with different routes for the mop and dust pipes...
zacky1223
Hi everyone any body uses roborock vaccum? I got some issue connecting to wifi. I am using a access point for wifi.
Does it affect?
Not connected to 5ghz wifi. Only 2.4ghz
v1hypersg
hi,
been using the roomba for 12 years and it seems to get the work done but as it is old
also have the bravaa but as it is 2 separate equipment and need to dump the dust bin, wash the mop cloth and such,
house has no carpet and just want to be spick and span with vacuum and mop the whole house,
anyone can share which is good ?
self empty dust bin. if no need dustbag would be good
water tank for clean and dirty water and can have detergent for more clean
wash mop head with hot water and self drying,
have camera for better detection,
stable software and cheap consumables
are my requirements
thanks in advance
