Robot Vacuum Cleaner
cyberklan
I just got the L20 ultra during 11/11.. very good deal with the kit. Tried once without wifi and impressive so far
lousylah
just bought with the recent BFCM sale but its pre-order so will have to wait, seems like a really good deal.
Can elaborate your “impressive” experience? For example have you used other robovac and how does it compare? Thanks!
cyberklan
To be fair, I’ve not had a robovac… used Electrolux before.. so coming from Electrolux to Dreame, it’s has been a v good experience
lousylah
Xiaomi has a new model M30 pro launched few days ago. Direct shipping to sg at $780. Looks quite high end
Wonder if I should wait for 12/12 to see if I should forgo warranty.. so far Xiaomi stuff serving me well
https://m.tb.cn/h.5l6xkKS?tk=SYcgW4l7pqN
Thanks, good share!
the suction power of 7k is up there with the flagship model from dreame, ecovac but around half price (vs retail). Defo a solid option.
the xiaomi models available at retail here are only 3-4k suction power.
MGeaR356
How good also no use if there is region lock.
Not familiar with this.. got chance it won't work at all with the app? Apparently my old roborock bought from sg seller seems like it's china set.. seems to work okay with mi jia app
hkchew03
go google on dreame/xiaomi/narwal robot vacuum first. The stake are high.
MrTheROCK
anyone tried purchasing from taobao for xiaomi m30 pro? got region lock? :o
NovelLobster
Hi, not sure if this thread still active, but…
my father went on Taobao to buy a Deerma DEM-A10. I’ve been trying to connect it to my Singtel 2.4Ghz network but keeps failing.
anyone knows why? The WiFi password is correct and I have turned off auto connect to 5Ghz network on my iPhone
is the deerma region locked or am I just doing something wrong? I set the region on the deerma app to SG. If I try to set it to China region, do I need VPN?
MrTheROCK
buying from taobao is always risky.
some got region lock
and u r right, if wanna connect to china region, vpn is needed :o
hkchew03
Region lock shouldn't stop you connecting to Wifi, its more blocking you from using it from the app. I would try to change the wifi channel and make sure signal is good with minimal interference.
