Ryzen System with Windows 7?
Crooni
gskill 3000 cl15 are almost all sk hynix (and maybe some lousy binned samsung)
sk hynix mfr/afr commonly only reaches 3000. the best binned are sold as 3200 16-18-18. so realistically they'll only work at 3000/2933. at best you might get 3200 cl16 at higher voltages and timings, but don't count on it.
croc1977
accessories already purchase left M/B and CPU
Just need to check something ...hopefully you guys can help
1) from i understand , if i use back my GTX 970i can still install win 7 . if i use dedicated AMD Graphics onboard then die die windows 10 . is that true?
2) MSI B450 Tomahawk or Gaming plus ?
shadow84
1. Wrong concept. It depends on your mobo BIOS whether it can accept wins 7 which i doubt so for B450 series.
2. I would go for the cheaper one?
singupingu
B450 Gaming Plus and Tomahawk is essentially the same board. The only few things I'll consider between this 2 are:
1. Do I want RGB on the motherboard?
2. Do I want USB 3.1 Gen 2 Type C on the motherboard?
If yes to any of the 2, go for Tomahawk.
If no, then Gaming Plus is the better buy.
Sent from OnePlus ONEPLUS A3003 using GAGT
croc1977
croc1977
i dont need RGB color...hate it
USB c is the small one for android phones rite?
noneed also..
want a better one for OC that all out of the 2
singupingu
noneed also..
Ya, USB Type C is the new Android heads, which are reversible like Apple's one.
Then get the Gaming Plus. B450 boards are not meant for hardcore oc. A mediocre oc should be fine but Ryzen 2600X don't have much OC headroom also lol.
michael_thm
croc1977
so should i get 2600 or even 1700?
croc1977
Games vs Productivity ? Which has more priority for you ?
I chose 2600 cos I play games more often than I perform productivity tasks.
games for me ..
like
SWBF2 , PES 2018 , FM 201x...some of the games i normally play
so i should save a few buck and 2600x down to 2600 ?
-Grift-
games for me ..
like
Frostbite games love cores/threads BF4 used 9/16 threads while BFV used all 16
ckling
I think u anyhow say leh, I used don't have such problems mentioned
sadly i know these issue but i think more issue on 10....really...all the sudden restart and patch....and data gone...
im not saying windows 7 won't happen but win 10 interface is more for touch screen...and the only windows 10 i have is a touch screen pavillion x2
-Synchronicity-
Just advise on what he/she wants to know. Ts should be responsible for his/her own choices regarding os choice.
xonix
games for me ..
like
Go check out the benchmarks for your games. More games are now benefiting from 6 cores or more but most are generally still reliant on high clock speed/ipc
That's why Intel coffee lake i5 still perform better at games despite Ryzen having 6 cores/12 threads.
Same reason why I skipped the 1700 and 2700 series as they have more cores but lower base clock. If you plan to do heavy overclocking, then consider the X versions.
