Samsung Galaxy note 2 tips & tricks plus issues.
tohchr
Anyone can test this?
Create a to do task, mine is on exchange server.
Set the task notification to sound let say 5 mins later.
Then reboot your phone. The task will still be there but once u reboot the phone, task alarm will not sound off. This is the first problem I'm facing with android.
kspace
However, still doesnt solve my choppy browsing on gallery. I using external sd card 32gb class 10. Abit disappointed given the specs of the phone. My old phone flipping through pics much smoother than this.
I agree with you, I also encountered this problem.. a bit disappointed.. somehow I guess the OS is not optimized yet which leads to the lag.
intenn
Can we still do screen capture by pressing home button + power button? I tried and it does not work. By pressing home button, it brings up the task manager.
Thanks in advance.
It is not by pressing + and home. Zzz
It is by pressing on iff button plus home button.
mamboeidos
dunno u all have this problems anot...but my spen damn sensitive.......hover over an item then they will click for me....even when i just moving my spen over the screen they will at times click for me also..
is this my spen prob or the phone?
captylor
Well, you're not alone. My S-Pen will occasionally act as if I am tapping on the screen even though it is just hovering over the screen.
SLstweeter
anyone encounter alarm issue for note 2? it only ring 1 secs and auto stop. no idea wat happen.
alarm: melody mp3 song
set to repeat weekly from monday-fri, already encounter few days this issue.
Is your "Turn over to mute/pause" activated? (under Settings>Motion) and your N2 happen to be placed face-down, or you have a flip cover over the screen?
and/or the option "Palm touch to mute/pause" - try unchecking it
I think I initially had this issue, where the alarm will sound for abt a sec and then it would auto go off too. Since I disabled this feature in Motion, it is fine now.
But these feature seems useful - wished there are options to let us disable it for our selected applications ie. clock, alarm...
manaeater
Hi guys, have anyone of you tried the S Note greeting card? Like uploading a custom created birthday card directly on the person's wall?
I tried drawing all sorts of stuffs but when I post, only e template appeared on e person's wall but not my doodle!
Am I doing sonething wrong..? Or does anybody can help? Thnx
longj49
has anyone tried to wake the phone by waving your hand over the screen? mine takes about 6-7 seconds, too long i think. is this the same with you guys?
bearzila
Bro/Sis, How to remove the slider/tray? Whats that thing call?
mberflame
For those who have problems with their 4G singals, such as keep jumping, try switching to GSM/WCDMA instead.
Works for me, hope this helps u guys
