Samsung Galaxy note 2 tips & tricks plus issues.
striker22
I notice there is some lagging when viewing photos (mostly 5 megapixels, around 1.2 MB) in Gallery, as in the photos will first appear blur and then become sharp. I have turned off all background apps n cleared RAM however the lagging is still there. Is this a known issue? My nokia pureview 808 and ipad do not have such lagging when viewing the same photos.
Can i check what microSD card you using?
steveyhere
I have 2 questions
Is there a way to change the skin of Samsung keyboard to mske the keys bigger? I don't want to switch to switchkey3 or other cos I use tge stylus as well?
The email client theme of Note 2 is too dark for my liking. Is there any way to change it as well?
steveyhere
2 more questions.
After rooting, are the s pen apps still usable?
Does anyone know someone experienced who can provide reliable rooting service?
fxloading
anyone encounter alarm issue for note 2? it only ring 1 secs and auto stop. no idea wat happen.
alarm: melody mp3 song
set to repeat weekly from monday-fri, already encounter few days this issue.
Jhyun
Tap on the More section, see if anything else is turned on?
I get the 1 second when i chose the Alarm Type as Vib and Mel, but once set to Mel it should be fine.
Kegwine
hi guys i have 2 questions,
first, anyone's battery diminishing very quickly? I'm using nova launcher, do you think that will affect it drastically? Because mine went from about a 24-30 hour use per charge to about 14-16 hour use per charge
secondly anyone here using tasker? I can't seem to get mine to work, following all the guides. I tried doing smth simple like "turn on wifi at - 11:01 am" doesn't work! I really like tasker and would like to learn how to fix it
fxloading
alarm tone: mp3 song
alarm type: melody
snooze: 5 minutes 3 times
smart alarm: 3 minutes
do you set repeat weekly? i think i encounter this because set repeat weekly. will try to set for one day alarm only.
anyway thanks :D
frizee
The little keyboard symbol at the top left hand corner always appear... Set up liao still have... Very annoying...
slang
what is this keyboard logo meant for actually. i have no idea y it keeps appearing too
NgiaoCi
It actually means the keyboard is "on".
Nothing much really... somethings a pop out message arrives and we reply and close, the keyboard is still "active", thus the logo....
jazzyjay
It will appear only when you are using the keyboard or when keyboard is shown.Example in sms mode, you using the keyboard to type a sms, it will show you the keyboard as well as the icon on the top left corner. Once you dismissed the keyboard, it will go away
joshy_aa
is it true that n2 keyboard doesnt come with autocorrect? ive tried to look for the function but couldnt find.
ceciliansc
Voice Command
Hi Note 2 users
Have anyone used the incoming voice 'answer' and 'reject' commands? Mine's function keeps disappearing after a while and have to restart to get it to work. Is this a bug inherent in this function?
Thanks in advance for any advice.
Cheers
tandesmond
Can we still do screen capture by pressing home button + power button? I tried and it does not work. By pressing home button, it brings up the task manager.
Thanks in advance.
striker22
I notice that browsing through my gallery, the scrolling/ flicking from one photo to the next can take quite a while for the image to be fully rendered clearly. It's like flicking through 5-6 pics and the next few will take quite a while to process.
The other thing i notice is that this is especially bad when there are faces in the pictures and the face detection is at work. Is there a way to turn the face detection off during playback?
dingdung
I'm also facing the same issue...
The photos are stored in your microsd card or built in memory? What class of microsd card u using? I guess browsing those stored in built in memory will not have lagging or rendering issue. More likely due to the formatting of the microsd card. As for the face detection i believe there's a way to remove that feature. I'm a newbie for android phone so need some time to explore the new os.
striker22
Ok, i just learnt how to remove face tagging, once you in the photo, hit the soft menu button and off face tagging.
However, still doesnt solve my choppy browsing on gallery. I using external sd card 32gb class 10. Abit disappointed given the specs of the phone. My old phone flipping through pics much smoother than this.
