Samsung Galaxy note 2 tips & tricks plus issues.
jspk777
N7105 Note 2 having wifi password problem
I just got my note 2 yesterday from singtel. Everything seems ok except wifi. it keeps prompting me for password and rescans and prompts for password again saying "password incorrect" below, but I use same password for iphone and no connection problem.
Anyone face this problem?
Do i need to do factory reset? how to do it? (sorry I'm very new to note2).
kelvinchewtl
Try restarting your router
manaeater
Hi guys, have anyone of you tried the S Note greeting card? Like uploading a custom created birthday card directly on the person's wall?
I tried drawing all sorts of stuffs but when I post, only e template appeared on e person's wall but not my doodle!
Am I doing sonething wrong..? Or does anybody can help? Thnx
Another qn, how do I add chinese character input to my keyboard ar?
Any help here guys...? Thanks!
panDaz
Well, you're not alone. My S-Pen will occasionally act as if I am tapping on the screen even though it is just hovering over the screen.
I got the same problem too! I tried turning the tip of the pen, and it works better now. No more auto clicking while hovering..
robinpok
I have this issue also, I wonder is it due to the screen protector I put as I rem before putting protector dont seem to have this problem.
longj49
has anyone tried to wake the phone by waving your hand over the screen? mine takes about 6-7 seconds, too long i think. is this the same with you guys?
never mind, found a solution. after rooting the screen can now wake up after only 2 seconds.:D
SPEED
Just got a Note2 from J2 Mobile
Does the back cover which is the speaker area
the plastic cutout has a small slight hump up?
Can feel it with your finger
I wonder this is defect or its samsung design?
manaeater
any1 can help with tis pls?
manaeater
mine have oso leh. a slight hump on the strip of plastic.
xrawrxx
Hi all, need a check on a issue. those with note 2 when you guys charge does it have a hissing sound (from the charger) which is quite audible and it stops when u are not charging your phone? it gets louder when getting to full charge.
i google and realise there are some charging noise but the noise i get is quite audible throughout the living room.
thank you very much!
Nitrile
sounds like that are usually caused by faulty capacitors.
oops : its normal according to some posts here.
dopeasskid
How do you activate the screen recording function? Videos on YouTube show that you have to press the power button and volume up button. But it doesn't seem to be working for me..
dopeasskid
Re: s note greeting. You need to get out of edit mode. Which is the first icon on the left. Tap it. Then it will save. Then proceed to click on the Facebook icon to upload onto the person's wall.
It's tricky.
