Samsung Galaxy note 2 tips & tricks plus issues.
kEvinErd
anyone here is a frequent user of the S-pen (stylus)?
do u usually write when placing your phone on a desk?
i noticed that my palm often hit the Back button of then phone when writing...and the process of writing was interuptted....quite frustrating
I thought when the s pen is in use, the soft keys will automatically be deactivated to prevent accidental presses. Or is that firmware-dependent?
Henabi
if I remember correctly, Samsung has this feature in-built into Note 2, which will deactivate finger inputs once you pull out the S-pen, or the S-Pen is hovering within certain distance from the phone...
but i think it only works with certain apps, probably S Note
transworld
Hi Bros, anybody using Sandisk SDXC 64G on their sets? Any issues regarding formating? Mine can't be detected by pc and phone. Thanks.
Henabi
one way to work around it would be to root NOTE II... unrooted only accept up to 32GB i think...
currypig... the quick glance using the S-PEN is quite sensitive. just hover the tip of the S-pen very near to the screen over your SMS or emails, a preview screen should pop up.
otherwise, try it while you press and hold the S-Pen button, while you hover.
Jhyun
Nope, it should be able to use 64GB even unroot.
The problem lies with the card, those SDXC cards are known to have lots of problems, especially the 64GB ones.
kingkangkong
pffffft the OTA update really isn't that great. Battery life has taken a hit. Previously it was stellar, now its merely good-ish. Any way to revert to the old firmware?
doomgaze86
I can't really get the palm swipe screenshot thing to work. Am I retarded?
P.S. Yes, it's already enabled in settings.
kingkangkong
did you use your whole palm? usually i use the side of my hand. the edge of your palm is perpendicular to the screen and just swipe across. try?
currypig
hey thanks for the reply, actually i was referring to the quick glance at the locked screen. I saw from youtube, jus need to swipe ur palm from the top to cover the LED light, the screen will light up showing the time and messages.
doomgaze86
Haha thanks, it turns out, I am retarded after all. Didn't realize the hand had to make contact with the screen. -_-
Hairyworm
I used to have Note 1. I can off the vibration and sound.
But not for my note 2. Any helps?
klaha81
Class 10? You need to format the SDXC into FAT32 format. Try using a program like EaseUs Partition Master. Mine is working perfect!
manaeater
guys ijuz gt my note2 white from SH ytd. network was fine at orchard ytd, but when i woke up at home (yishun), keep no network at all...y like tat...? even after select SH as my network, it only says "registered with network", but nothin happens....now can oni use wifi........pls help..!
hero001
Just curious whether you did the software update?
I'm staying in yishun too and i'm getting 4g network on my phone. Like a shiok!
tohchr
Which part yishun? Inside house also got 4g?
