Samsung TV problems discussion thread
Rock
My Samsung 32N71 LCD TV is already in used for 5.5 yrs and still going strong. It may be due to higher end model at that time (as compared to R and S series) and panel is Samsung panel.
However, will not be getting Samsung again if the current one spoil.
Sony TV is not in consideration as well since having experiences on facing defects after about 2.5 to 3 yrs of usage.
bratpig
I am still waiting for my Hitachi lcd tv to die, which I bought in 2005 or 2006
thechariot
samsung tv with antenna having problems..
hi,
i got an old samsung plasma tv 42" and had been using an antenna to view local channels. until recently, the channels now like skipping.. u know like as if i'm on a stb.. the channels now are like encrypted.. no matter how i fine tune or retune the channels, all seems the same. i'm a using this daiyo antenna. i plugged in my laptop and set to PC, its fine. but only in the tv mode, the channel signals are like scrambled.
can advise me whats wrong?
tia.
dragonewt
anyone know wats this problem?
model:40 inch samsung led tv. UA40D5000
bought a yr ago.
sometimes the picture gets distorted on the top half, then the color becomes very dull, then a while later turns normal again.
Normally last 5-10 secs.
this is a photo showing the problem:
imageshack.us/photo/my-images/195/p9240332.jpg
i search on youtube and find this guy's tv same problem (only that his is on the right side)
youtube.com/watch?v=H9iuJUKzuH4
anyone got a clue wat cause the problem? interference from outside or internal problem?
thx.
mrsun18
Either your antenna (indoor?) is not receiving enough signal for the TV or your TV tuner is faulty.
touchme
Borrow thread..
Random blue artifacts and under saturated tint over original picture.
Defects only thru hdmi (old lcd, 1x hdmi port only). Thru AV and VGA is fine. Tried different players, different hdmi cables all cannot.
Could it be circuit board issue (gone case) or hdmi port pin misalignment or broken (can diyfix)?
sunsetbay
Moderator
Moderator
bought a yr ago.
thx.
help u to embed~ :s22:
Samsung LCD TV LN46A550 going bad (distorted video on right side) - YouTube
Rock
Bought a year ago means still cover under warranty.
Call out Samsung to send their service man to check your TV.
Rock
Ehh back when my 40inch samsung LCD spoil right. I call them down Juz 1 mth b4 warranty end. And I dub even have the warranty card anymore. They check from their side the serial number. They came and say my tv parts no more. Cannot be repaired. So they say they will give me a cheque for the refund of the tv. But got depreciation. I bought the tv for 2499 and they refund me 2074. I only use the tv for 35mths. Super awesome lol.
Super awesome + 1
With the refund of about 2.1k, you can buy a new and bigger TV plus have some spare cash for others.
My case is Samsung 40" LCD TV found faulty within the first year and repaired twice also can't get it fit. Finally Samsung replaced a newer model TV. Your case is refund. Good!
Auspicium Melioris Aevi
My 7yr old Bravia sudden had this problem too! Top 20% of the screen is fuzzed, liked there is some disconnect & really slow speed and the prob is "permanent" not like what the 10s prob the TS experienced.
Because of this, I decided to buy a new TV, cos I guess the repair is not going to be worth the money & effort.
update...
After installing my new TV, the old Bravia zonked!
Wonder how much the karang Guni man will pay for this gone case set
update...
the karang Guni man took it away for $2 :(
vin002
Check out my price for 50" samsung 3D Smart LED TV! You just need to top up $225. LOL...
Silenced
Incapabilities of Samsung TV technician
Hi,
last Wed my Samsung tv has some problem with the sensor,so i called up to the support centre and they send their technician to my house.
But after changing a couple of parts,the problem still persist,so they decided to bring the tv back to workshop.Until yesterday,they return the tv to me and it works fine.
Then this morning the problem come back again :eek:,,they dont seems to understand how to fix my tv.
And their technician are only able to come tomorrow.:s22:
My questions are,is there any department i can lodge a complaint regarding this issue?
Can i lodge a report to CASE?
Thanks
wwh5210
Hi,
Thanks
You can call their customer service hotline and ask them to transfer your call to the technical department. Just request to speak to their manager first before going up all the way to CASE.
nomoney25
I feel it is somehow quite unreasonable to expect them to come immediately after u made a complaint.A one day wait is acceptable. Imagine samsung technician suppose to come tmr and while waiting for them, they call u and inform u that they cant made it because they need to fix someone whose tv is bigger..If samsung still do the servicing and repairing under the warranty period, there is nothing CASE can do.
I guess the problem of your tv is much complex since it had been repaired and unable to fix, recently there was a incident where a owner managed to claim 80% back of the tv price after using for 2.5 years as Samsung is unable to fix it and find a replacement set.Quite worth it as tv price drop a lot now.
Streetwise
Hi,
Thanks
I empathise with ur situation but from ur description, Samsung has responded positively and is trying to repair ur TV. If u're still unhappy....just take it up with Samsung management.....though I personally feel that is no case for CASE to take up....for now.
Silenced
Yesterday i requested them for a 1 to 1 exchange so they send a technician to my house n take a picture of my receipt to be submitted for 1 to 1 exchange approval,and promise will let me know the status by today.
Then i waited until 4pm and no one yet to call me so i call them la,and the their reply was"the approval would take 2-3 weeks for them to processed".Talk about efficiency... :eek:
this is the problem of my tv :s22:
nomoney25
Keep us updated, at least we know what Samsung is going to do to your tv.
I will say 2 ~ 3 weeks of waiting is a bit long.Especially remote controll is so important.
Best is refund u the money .
keanteac
Why you created so many thread about Samsung ?
Why you so hate Samsung ?
Are you employed by Samsung competitor ? :s11::s11::s11::s11::s11:
Hi,
Thanks
mikezuper
One of the reason I am shy of Samsung TV product - had bad experience last time
