Share your battery saving method!
Angtehkor
For email, you may try bluemail, can add in more than 1 email account.
I don't game at all so naturally,my usage is light. But if you game, why uninstall it? You have more important things to worry other than battery life. Lol
My game is just those ah pek play one>slot machine game. Delete also nevermind because in the past I spent too much time on these slot machine games.
1982-1994
Samsung browser users, don't you find that it is battery friendly? Or no difference?
Angtehkor
The battery drain very slow because of the dark mode unsure about other browsers. Use to have brave browser but the dark mode is not as friendly as Samsung browser.
firesong
Deluxe Member
You can enable dark web contents for Chrome too.
chrome://flags
1982-1994
chrome://flags
Not really well implemented, same as brave browser.
1982-1994
In boon lay.
In Punggol.
Signal strength is one of the factors that causes battery drain. The higher the dBm,the higher the battery drain. But it is unknown why M1 network tend to drain battery as high as 4% hourly when the phone is on idle mode. Which results either Android system or cell standby appears on the first in the battery usage list.
IMO,>90dBm is considered bad signal strength and is detrimental to battery life.
Call me ridiculous,before I ported from M1 to singtel>starhub, I bought the latter two prepaid cards to test idle drain. So far so good.
Maybe that explains why M1 users complain of bad battery life of their phones.
Angtehkor
My phone is at 84% yesterday at 9.00pm decided to turn on airplane mode as I want to sleep. Today 9.00am turn off airplane mode and my phone is at 83%>12 hour drop only 1%-1.5% in airplane mode when I sleep
jcw_17
Regardless of what Samsung model, share your settings!
Under display settings:
Auto brightness off. Set at 35% indoor, 45-50% outdoor.
Set to the highest screen resolution.
Blue filter on at maximum.
Night mode on.
Screen mode natural
Screen timeout 2 mins
Edge panels/lighting off
Navigation bar-full screen gesture with one hand operation app installed.
how do u install NAV bar with full screen gesture? applicable to note 8?
Angtehkor
Ok ok we know the standby of your phone is excellent (but on the expense of plastic build and NFC)
Because my phone cheap mah that why lot of features missing in my phone. And because this the only 6000mah Samsung phone and I don't know how long Samsung is going to produce another 6000mah phone. By the way I install back my Monopoly slot game because I cannot do without it but limit myself to play once a week every Sunday.
