SIMBA Fibre Broadband
Nefalrin
eh... why not cat7 but cat6?
Cat 7 cables offer better performance, shielding, and future-proofing at a higher cost, but for most everyday home or small office use, Cat 6 is generally sufficient.
Cat 7 for 100 metre and Cat 6 for 55 metre is enough.
Both also can
No point to use CAT 7 (or CAT 8) which requires shielding which typical contractors can not do properly at the home setup. In fact, it may even give you worse results without proper shielding compared to CAT 6.
Unshielded CAT 6 (or CAT6A if you want) is good enough for home setup and no issues with 10Gbps (up to 55m for CAT6).
If you plan to be even more future proof post 10Gbps, then Fibre is the way to go for home environment.
Shielded CAT6A or CAT7/8 may be more useful in commercial setup.
Reference:
https://community.fs.com/article/should-we-use-cat6-or-cat6a-for-10gbase-t.html
probably because 6 is a good number.
cat 6 and wifi 6 are good enough
There is a difference here.
CAT 6 is good for 10Gbps for home environment.
WiFi 6 is good enough for most cases now. However, if you want to have Wireless device breaking the 2Gbps speed barrier, then you have to use WiFi 7 router/clients on the 6GHz band with 320MHz channel bandwidth (2Gbps to 4Gbps).
A7997A
Any idea if there is an option to get a 10G ONT with SFP+ LAN port ?
10G LAN port will require either RJ45 transceiver or switch with RJ45 10G ports, which are more costly and hotter, which is not a great idea given the confine space in tiny closet that the fiber termination point in new HDB flats.
Only VQ provides the XGS-PON ONU Stick option at S$99 top-up.
As for 10G LAN port on the XGS-PON ONT -- it is not too bad if just use an SFP+ Copper module on your 10G pure SFP+ switch, Or if you have a 10G switch with mixed 10GBaseT port and SFP+ port. Then your other 10G devices can use SFP+ interface.
SFP+ copper module is not too expensive -- you can get them from 10Gtek with reasonable price, or other brands. They are hot indeed but you can use a USB fan if you want.
I do not have too many 10G devices but I am buying the following from Hasivo.
1) 8-port pure SFP+ ports, RMB 499
2) 2.5G switch with one SFP+ uplink and one 10Gbase-T RJ45 uplink, RMB 399.
I have three more 2.5G switches with dual SFP+ uplink.
Planned connection scheme in the future (not done yet).
1) with Singtel unbridged ONR in the Living Room
Singtel ONR 10G LAN port (unbridged) --> 10G RJ45 LAN port of Hasivo 2.5G switch
SFP+ port of Hasivo 2.5G switch --> DAC cable --> Hasivo 8 ports SFP+ switch
Living room Hasivo 2.5G switch 2.5G LAN ports --> 2.5G wired device in the Living Room
Hasivo 8-port SFP+ switch with SFP+ Optic module --> Fibre cable to the bedrooms --> bedroom Hasivo 2.5G swtich SFP+ port with SFP+ Optic module x 3
Bedroom Hasivo 2.5G switch 2.5G LAN ports --> 2.5G wired device in the bedrooms
Bedroom Hasivo 2.5G switch SFP+ port with copper module (hot) --> one 10 G wired device in the bedroom
2) with Singtel bridged ONR (If I can get it bridged) in the living room
Singtel ONR 10G LAN port (bridged) --> Miniroute R1 Intel N100 soft router SFP+ ports with 10G SFP+ copper module (hot, using USB fan to cool it down)
Miniroute R1 SFP+ LAN port --> DAC cable --> Hasivo 8 ports SFP+ switch
Hasivo 8-port SFP+ switch SFP Ports with SFP+ Optic module (x 3) --> Fibre cables to the bedrooms --> Hasivo 2.5G swtich SFP+ port with SFP+ Optic module for each bedroom (x3)
WatCult
Just take note you may need a copper SFP+ 10G module (pretty hot) for the SFP+ LAN port.
How much the cost for the SFP+ 10G module? Probably need it to connect to RJ45 port in the living room that runs to my main switch in my study.
The switch also need to change if i need to run 10G backhaul.
Btw anyone know the turnaround time for Simba and NLT to get the port up?
10Gtek official Taobao shop: RMB 178 plus GST plus shipping. You need to specify the switch to use to guarantee compatibility.
【淘宝】限时官方立减20元 https://m.tb.cn/h.gOUCGGx7DEG6wzI?tk=Hh6s34avHmq CZ8908 「万兆SFP+电口光模块RJ45光转电转换10G光口转电口模块自适应兼容5/2.5/1.25G锐捷思科华为H3C小米10Gbase-T」
点击链接直接打开 或者 淘宝搜索直接打开
There are of course cheaper ones but 10Gtek seems to be the more recognized brand.
https://forums.hardwarezone.com.sg/...ubiquiti-vs-10gtek-simple-test.7036627/page-4
I use another brand from Ganwen 感闻 with my Ganwen/Hasivo 2.5G switches and Miniroute R1 N100 mini PC and it seems to work as well (bought 4). But Ganwen SFP+ copper module is at RMB 189 (so more expensive) and some people in this forum suggest not to buy from Ganwen.
Any recommended 10G switch for best compatibility?
Not an expert here.
It also depends on your budget of the 10G SFP+ switch.
Unmanged and more recognized brand yet low cost --> TP-Link China TL-ST1008F
https://www.servethehome.com/cheapest-10gbe-8-port-switch-tp-link-tl-st1008f-review/
Managed and more recognized brand yet low cost --> TP-Link China TL-ST5008F
I bought TP-Link China TL-SH1008 8-port unmanaged 2.5G switch a few years ago and it is okay (a bit hot, probably due to old chipset).
You can see I am going with even cheaper brands like Hasivo and Ganwen for 10G stuff. Hasivo and Xikestor seem to be two low cost brands which have better recognitions.
More expensive and better brands --> MikroTik, Ubiquiti, etc.
But I guess you may want to consult brother @TanKianW or other experts.
https://forums.hardwarezone.com.sg/...projects-include-10g-network-upgrade.6341518/
WatCult
Thanks for highlighting! I went to take a look at TP-Link China router and found the TP-Link BE13000. That's look interesting. It might also relief the trouble on getting a SFP+ module.
It is a decent router if you do not mind the so-so Firmware. It has dual 10G RJ45 ports and quad 2.5Gbe ports.
BTW, even though it is listed as BE13000 but in reality is more like BE10000 triband, just like Xiaomi BE10000.
https://m.tp-link.com.cn/product_2876.html?v=spe&dt=m
IEEE 802.11a/b/g/n/ac/ax/be
Max WiFi Combined Speed
13000Mbps(2.4GHz 1376Mbps,5G1 5765Mbps,5G2 5765Mbps*)
*Region settings for China/Singapore
5G2 will not support 160MHz, max speed will become 2888 Mbps. Total combined speed will be BE10000.
slash
Both also can
icic. I just converted back to LAN connection, wifi 6 still not as good. I'd tot i don't need to pull LAN when i changed my pc location. Anyway my house is old, so got exposed cable trunking, just hide it in there. I bought the cat 7 flat type from taobao, 15m only 10+ .... challenger selling 35+ for 20m...
slash
Reference:
sounds too chim. I got 2 other short cat 7 (supposed shielded, cos super thick), but impossible to bend. so I just get those flat ones that can easily get through door gaps.
yea, saw the transparent fibre thingy singtel offers with huawei setup... maybe next time when all prices come down, will have a lot more choices. Now just use whatever fits the budget :)
Sglastexile
Anyone facing slow loading of mangaplus website when switch to SIMBA fiber too?
fast loading with eight/ vivifi but when using SIMBA fiber, occasionally loading of website like mangaplus is slow.
Nefalrin
Just change your dns to Cloudflare or google
