IMHO no point to consider SIMBA 10Gbps now that Starhub 5Gbps offer at S$29.55 per month (with free HB710, dual 10G ports, triband BE18000) or M1 6Gbps plan new user offer at S$34.90 per month (with free Archer BE805, dual 10G ports and quad 1G ports, triband BE19000) are way better plans to go.
My reasoning of not using SIMBA --> lack of support so it is not good for average users, CGNAT without static IPv4 add-on so it is not good for power users.
Take note you need to get a 10G capable router to enjoy the higher bandwidth. Starhub/M1 already provide 10G capable rotuers with the above-mentioned plans. For SIMBA, you need to pay S$159 for a lower grade D-Link router (dual band BE7200) or S$369 for Amazon eero Max 7.
You may say I am biased but you can always check out the sticky thread to come out with your own conclusion.
⚡️[Official] README First! 2025 SG ISP Comparison & Latest Promo Deals!
https://forums.hardwarezone.com.sg/...sg-isp-comparison-latest-promo-deals.6665380/
I am on an old starhub plan.
So would it be worth considering if we sign SIMBA / Whizcomms 10Gbps + buy BE805 from Carousell?
Impressive.Just activated my Simba 10g. For your reference.
Wired Setup:
FibreTP -- ONT -- Inbuilt CAT6 cable from DB box to Room -- TPLink Archer BE800 -- OWC Thunderbolt 10G Ethernet Adaptor
Wireless Setup:
FibreTP -- ONT -- Inbuilt CAT6 cable from DB box to Room -- TPLink Archer BE800 -- Pixel 9 Pro (on Wifi7 6Ghz)
nope , never...dont intend to do that. lazy to shift things around. haImpressive.
But ever plug direct to ont bypassing the in-wall cabling, any diff?
no, they're using CGNATDoes Simba offer static ip?
No option for static ip address either even if you wanted to pay.Does Simba offer static ip?
Just when I wanna sign up, no more M1 6Gbps at S$34.90 per month :sNo, just subscribe to M1 6Gbps at S$34.90 per month with free Archer BE805, which is of much better value.
Too many ppl chiong this plan?Just when I wanna sign up, no more M1 6Gbps at S$34.90 per month :s
M1 6Gbps offer is still available for sign-up in M1 shop.
New home offer: S$34.90 per month with free Archer BE805.
Switching from other ISP offer: S$35.90 per month with free Archer BE805.
hi may I ask why the M1 6gb is better than simba 10gb where it is cheaper at $30/mth?No, just subscribe to M1 6Gbps at S$34.90 per month with free Archer BE805, which is of much better value.
